Date/Time: Mon, 16 Sep 2024 19:21:21 +0000
Graphic
View Count: 898
[2014-07-11 01:52:07] |
User22591 - Posts: 133 |
I have lost my images on top of my screen such as the chart value crosshair and line etc. How do I get that line back? i.e. the crosshair line drawing that is on top of screen. |
[2014-07-11 03:17:22] |
It sounds like you are referring to the ToolBar. Refer to the documentation here for making the ToolBar visible: https://www.sierrachart.com/index.php?page=doc/doc_WindowMenu.html#ToolBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-11 03:17:31
