Date/Time: Wed, 27 Nov 2024 12:32:20 +0000
display seconds of clock
View Count: 321
[2023-08-09 11:43:22] |
User278398 - Posts: 291 |
how can i display "clock" study second only (now i see hours min and seconds together ) /// if the solution is by "countdown timer" study, so please explain how to get it work. many thanks. |
[2023-08-09 14:37:16] |
John - SC Support - Posts: 36309 |
Please let us know exactly what you want to see and we will see if there is a way to do it. We are not fully understanding what you are looking for in terms of the clock in seconds. Do you want to see the number of seconds that have passed since midnight? Such as if it is currently 09:24:00, you want to see 33840 seconds? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-09 14:45:00] |
if the time is 09:31:24 so i want to see only "24" |
[2023-08-09 14:59:23] |
Use a Spreadsheet Formula study and enter the following formula: =SECOND(NOW()) Then you can use the Text Display for Study to display those seconds. Be sure to set the "Value Format" of the Text Display for Study to 1 in order to just see the seconds. Refer to the following: Spreadsheet Formula Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
