Date/Time: Wed, 27 Nov 2024 12:37:22 +0000
Stop Loss and Target Limit Disappeared
View Count: 724
[2023-08-09 01:35:40]
HiberBac - Posts: 3
Hi There,
I have an open trade with stop loss and a target limit set.
I closed Sierra Chart because I'm driving. When I opened it back after an hour or so, I can only see my entry price on my chart but my stop loss and target limit is gone.
Questions:
1. Why was my stop loss and target limit disappeared?
2. How can I set a stop loss and target limit with an open position?
imageOpen_Position.png / V - Attached On 2023-08-09 01:35:20 UTC - Size: 4.99 KB - 83 views
[2023-08-09 13:54:51]
John - SC Support - Posts: 36309
There is no reason why they should have been removed.
You would need to check the Trade Activity Log and look through it to find if those orders were truly removed for some reason, or if they are just not showing in the chart (which also should not occur). Refer to the following for information on how to adjust the filters to find certain orders:
Trade Activity Log: Viewing Historical Trade Activity
If you find the need to add attached orders after an initial order has been placed, then you can do this by using the Order Type of "Send Attached Orders - Position/Price". Refer to the following:
Order Types: Send Attached Orders - Position/Price
