Date/Time: Wed, 27 Nov 2024 04:59:17 +0000
Resolved - ACSIL - access to Chart Settings - Volume Filter
View Count: 1585
[2014-07-10 23:51:14] |
ejtrader - Posts: 688 |
SC Team - Would it be possible to provide access to the Volume Filter settings through ACSIL? Would like to dynamically change these values through ACSIL/Keyboard combination quickly if this is technically possible. Thanks http://screencast.com/t/eINwNstoYdjT |
[2014-07-11 17:22:34] |
Yes, we can add support for this.
[2014-07-15 16:10:37] |
Thank you SC Team. Would you please update this thread - whenever you get to implement this. thanks |
[2014-07-26 08:41:39] |
These new ACSIL variables will be out in the next release.
[2014-08-04 07:56:40] |
SC Team - Thanks for adding this feature. Is there any function to read the current value of filter settings? Issue at hand - Trying to control this through ACS toolbar buttons - but the persistent variable used for this is getting reset - with chart reload. If there is a way to read these filter settings, I would initiate them to current filter settings. Thanks Date Time Of Last Edit: 2014-08-04 08:01:02
[2014-08-04 08:32:58] |
You just use the same variables. They are Read/write.
[2014-08-04 23:12:06] |
Thank you SC Team. All good with this aspect :)
