Date/Time: Wed, 27 Nov 2024 12:22:23 +0000
Trade Mgmt by Study not working Version 2528
View Count: 337
[2023-08-08 18:54:14] |
User104854 - Posts: 456 |
I just upgraded to this version. I use a spreadsheet and the trade mgmt by study, along with the custom study buttons to move targets and stops with attached orders. None of it is working now. The spreadsheet says where the order is supposed to be placed but the attached order is not going there.............on any of the buttons. I know it's this version and it is something that you guys changed because I've never had an issue with this. How do I fix this? I can't trade without it. Just went back to 2504 and everything is working fine. Just like it should. What happened??? Please fix it. Date Time Of Last Edit: 2023-08-08 18:59:41
[2023-08-08 20:59:54] |
John - SC Support - Posts: 36309 |
We just did a quick test on versions 2528 and 2533 and we do not see any issues. The Enable/Disable Control Bar button is working and the Limit order we told to move, went right to where the Spreadsheet study Column K is set to. We also checked the code for the Trade Management by Study study and the last time there was a change to this study was on February 20, 2023 and the change was minor (adding brackets and changing a word for the control bar button name). Please get us the chartbook and the spreadsheet that has the issue (and let us know the chart) and we will see if we can reproduce it. You can attach the files privately if you wish. Refer to the following instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-08 21:25:28] |
Ok. I'll try again and get that together if necessary. Thank you. When you say the 'Enable/Disable Control Bar button' is working what are you referring to? One of the studies? Appreciate it. |
[2023-08-09 13:41:39] |
You mentioned Custom Study buttons. We assumed you were referring to the Enable/Disable option with the Trade Management by Study where it is associated with a Control Bar Button. Refer to the item named "ACS Control Bar Button # for Enable/Disable" in this section: Attached Orders: Trade Management by Study Input Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
