Date/Time: Sun, 08 Sep 2024 01:25:59 +0000
Denali Natural Gas Symbols
View Count: 383
[2023-08-08 11:58:12] |
User417302 - Posts: 67 |
Is it possible to have the following natural gas symbols added into the Denali feed? UKG TTE TTF JKM I tried adding them myself but I could not get them to load. Thanks, |
[2023-08-08 15:28:25] |
Sierra_Chart Engineering - Posts: 16292 |
What symbols are these specifically? What exchange are they on or exchanges?
[2023-08-08 16:46:18] |
They are on the NYMEX. TTF = Dutch TTF natural gas calendar month TTE = Dutch TTF natural gas (usd/mmbtu) front month UKG = UK NBP calendar month JKM = LNG Japan/Korea (Platts) |
[2023-08-09 18:37:38] |
Thank you. We will work on adding these.
[2023-09-12 09:57:30] |
These have now been added for the SC Data-All Services service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
