Date/Time: Wed, 27 Nov 2024 12:31:18 +0000
[User Discussion] - futures contract back adjustment inverse
View Count: 280
[2023-08-08 10:59:07]
Bankson H - Posts: 15
Is it possible to inverse the adjustment for "Volume based roll over, Back adjusted"?
So instead of that the last price from the previous contract will be brought to the new/current contract, the price from the new/current contract will be brought to the last price from the previous contract.
Regards
[2023-08-08 14:00:28]
John - SC Support - Posts: 36309
This is not supported.
[2023-08-08 14:16:55]
Is there a way to change the adjustment?
[2023-08-08 19:44:34]
You can change the adjustment amount for the previous data. Refer to the following:
Continuous Futures Contract Charts: Controlling Rollover Amount for Back Adjustments
And, you can adjust the current data by using the "Real-Time Price Multiplier" and the "Historical Price Multiplier". Refer to the information at the following link (and the section right below it):
Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
