Date/Time: Wed, 27 Nov 2024 13:06:47 +0000
Teton order routing for 2 sierra instances
View Count: 224
[2023-08-08 08:22:53]
GuillaumeJ - Posts: 10
Hello, so I am used to run two sierra instances with the Denali subscription for 2 machines (I recently switched to only one just for the month of august). I was previously using two rithmic routing (one for each sierra instance) with Denali. I now want to move from Rithmic so I recently witched to Teton with AMP futures. The question I have is, how to be able to run the two instances with Teton and Denali on both. I asked AMP and they explained that Teton is linked to my sierra username so I can only have one set of credential per sierra account, can I still run both sierra instances as described above ?
If not, give me the best setup for my current situation please.
Also as an alternative will I be able to use Teton + Denali on one and CQG routing + Denali data on the other ? I remember that you guys have issues with CQG so I don't know if it would work.
