Date/Time: Mon, 25 Nov 2024 23:32:26 +0000
numberbars font size
View Count: 319
[2023-08-08 05:06:13] |
Peeter Jakobson - Posts: 7 |
the text (numbers) are overlapping within each candle. How do I change the font size without changing the time or range or volume increment?
[2024-01-26 15:07:56] |
User806994 - Posts: 1 |
the numbers overlap!! on a numberbar chart, how can this be fixed?
[2024-01-26 17:11:06] |
John - SC Support - Posts: 36286 |
Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart Keep in mind, given the amount of information in the Numbers Bars chart, there is a tradeoff that you will have to make between the size of the text and what you can fit on the screen. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
