Date/Time: Wed, 27 Nov 2024 13:04:12 +0000
.dly files that are 10+ years old
View Count: 281
[2023-08-08 01:40:59] |
Dirty Moose - Posts: 6 |
I'm not sure what I did, but I'm downloading.dly charts from 2012. I looked thru all my charts and don't see anything requesting data from that far back. Did I break it? =) https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=84696 |
Capture.JPG / V - Attached On 2023-08-08 01:34:58 UTC - Size: 69.69 KB - 86 views Capture.JPG / V - Attached On 2023-08-08 01:38:15 UTC - Size: 69.69 KB - 91 views Attachment Deleted. |
[2023-08-08 08:15:35] |
Sierra_Chart Engineering - Posts: 17191 |
This would be the result of using the Continuous Futures Contract Chart feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-08 09:33:00] |
Does this have a negative impact on how Sierra runs? Does it slow it down at all?
[2023-08-08 10:45:14] |
To some extent. The more data that is loaded in a chart, the more processing there is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-08 10:45:20
