Date/Time: Tue, 06 Oct 2026 04:51:01 +0000
SC 1157 -> wrong CD with IB stocks
View Count: 1184
[2014-07-10 17:50:27]
User626121 - Posts: 82
Cumulative Delta for IB stocks is wrong since upgrading to SC version 1157.
[2014-07-10 18:00:53]
You cannot get accurate bid volume and ask volume with Interactive Brokers. It is not possible. Cumulative Delta Bars relies on bid volume and ask volume.
In newer Sierra Chart versions, the historical data for US stocks is downloaded from the Sierra Chart Historical Data service. For more information refer to the version notes for 1141 here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1141
The Sierra Chart historical data has very accurate bid volume and ask volume. So in newer Sierra Chart versions, for the historical data download, the Cumulative Delta Bars study will be more accurate.
If you require accurate data, you need to use the Sierra Chart Exchange Data Feed:
Date Time Of Last Edit: 2014-07-10 18:01:12
[2014-07-11 03:49:37]
We may have misunderstood the problem. Please give us the symbol of a stock where the Cumulative Delta Bars looks different.
In the case of stocks, the volume from Interactive Brokers is now multiplied by 100 to create actual volume.
To ensure consistent volume in the chart, go to the chart and select Edit >> Delete All Data and Download .
