Date/Time: Wed, 27 Nov 2024 13:00:17 +0000
Trading Micro from a Mini Chart
View Count: 1001
[2023-08-07 21:00:24]
User75949 - Posts: 118
It is very convenient to trade MICROS observing MINIS data (volume and Order Flow)
I see this can be done using the "Trade and Current Quote Symbol (Action)" on the Chart Setting Menu on *Symbol putting the Micro Symbol and putting "Yes" on the following line "Use As Trade Only Symbol".
I setted this up in this way as you indicate here Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
It seems ok but when I go into Trade Activity Log, even if it shows trades on the Micros Symbols, profit and loss are calculated on the MINI...
I still didn't try this live...
Is it a bug or do I miss something?
Regards
[2023-08-08 08:55:53]
Sierra_Chart Engineering - Posts: 17191
Are you sure?:
Refer to:
Profit/Loss Calculations and Symbol Settings
Date Time Of Last Edit: 2023-08-08 15:20:26
[2023-08-08 14:17:26]
yes, if i put the Micro on the main Symbol it calculates everything correct, but if I use the Trader and Current Quote Symbol (Action) line putting the MINI on the Main Symbol and the Micro on the Trade and Current Quote Symbol (Action) it calculates P&L on the mini even if on the Trade Activity Log shows the correct symbol (micro).
Attached images of it, -4.25pt on the Micros should be -8.5$ not -85$
Please let me know if there is something that I'm missing
Tks
regards
imageChart Dom & Chart Settings.jpg / V - Attached On 2023-08-08 14:16:14 UTC - Size: 542.26 KB - 146 views
imageTrade Activity Log.jpg / V - Attached On 2023-08-08 14:16:27 UTC - Size: 175.37 KB - 122 views
[2023-08-08 15:26:00]
Set the Currency Value per Tick setting in Chart Settings to what is required for MNQ:
Chart Settings: Updating Currency Value per Tick for Trade Symbol
