Date/Time: Wed, 27 Nov 2024 12:40:19 +0000
ACSIL - Chart number parameter for sc.GetVolumeAtPriceDataForStudyProfile()
View Count: 470
[2023-08-07 19:48:10] |
LudaTrades - Posts: 27 |
I am using sc.GetVolumeAtPriceDataForStudyProfile() and sc.GetNumPriceLevelsForStudyProfile(), these work great for profiles on the chart. I would love to reference profiles on other charts just like sc.GetStudyPeakValleyLine() does. Is this possible?
[2023-08-08 20:33:00] |
RB2703 - Posts: 2 |
Can you add the ChartNumber to the beginning of the StudyID?
[2023-08-11 03:10:08] |
No unfortunately the function calls for a StudyID int only. int GetVolumeAtPriceDataForStudyProfile(const int StudyID, const int ProfileIndex, const int PriceIndex, s_VolumeAtPriceV2& VolumeAtPrice); int GetNumPriceLevelsForStudyProfile(int StudyID, int ProfileIndex); I have exhausted all options trying to reference a volume profile that is located on another chart. There simply needs to be a chart number parameter in this function to do it. SC-Team I know you guys are understandably busy, is there any chance on adding this to a future update? The benefit for us would be long lookback profile values available on charts with limited days to load for performance. A 5 day footprint chart with access to 3 year VbP data for example. |
[2023-08-12 18:45:31] |
I have built a workaround study that uses persistents to obtain this info. It is possible, with this I'm all set.
