Date/Time: Wed, 27 Nov 2024 12:24:07 +0000
Not Able to Manually Adjust Drawn Volume Profiles
View Count: 235
[2023-08-07 17:03:25] |
User940772 - Posts: 74 |
I am not able to manually adjust my drawn Volume Profiles. I have been using this feature for years without any problems. I though I might have turned something of inadvertently but can't find anything in the help files. It is working normally in two other instances of Sierra. I even tried transferring a chart over from one of them with the same results ... cannot manually adjust. It's certainly nothing imperative but would like to resolve the issue. Thanks
[2023-08-07 17:16:52] |
John - SC Support - Posts: 36309 |
Check the setting for "Tools >> Tool Settings >> General >> Enable Drawn Volume Profile Selection". This should be set to "Yes". Refer to the following: Chart Drawing Tools: Enable Drawn Volume Profile Selection (Global Settings >> Tool Settings >> General >> Volume Profiles) Also check the setting above it for how you can select the Drawn Volume Profiles. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-07 17:39:06] |
Hi John, right again. For the life of me I don't know how I turned that off but was looking at tool configs and settings over the weekend. Had to have done it then. Always appreciate the help and quick response. Thanks-
