Date/Time: Wed, 27 Nov 2024 13:02:37 +0000
PositionQuantity Issue
View Count: 287
[2023-08-07 15:32:26] |
User807787 - Posts: 41 |
For example, connected to chart TSLA_MBO/TSLA-STK-SMART-USD[M] I am filled in a trade through interactive brokers. PositionData.PositionQuantity; is returning 0. However, when I switch to TSLA_MBO/TSLA[M] I am filled in a trade and PositionData.PositionQuantity; is returning the correct amount. Any reason for this? Fix? Date Time Of Last Edit: 2023-08-07 21:41:37
[2023-08-08 08:22:11] |
Sierra_Chart Engineering - Posts: 17191 |
What is the exact symbol that you see for this particular stock position in Trade >> Trade Positions Window? That would be the symbol you need to use for the Trade and Current Quote Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-08 08:22:35
