Date/Time: Wed, 27 Nov 2024 12:31:03 +0000
Files need copied for sub instance?
View Count: 233
[2023-08-07 14:36:17] |
TopGunTrader - Posts: 172 |
Hi, I'm typically just run one instance but found CPU getting high % so moving some charts I use to sub instance and wondering which files I need to copy over so all styles, hotkeys etc work just like regular main Sierra? Thanks |
[2023-08-07 15:13:09] |
John - SC Support - Posts: 36309 |
If this is the first time you are opening a Sub-Instance then all the files will get copied automatically. But, if this is an existing sub-instance, then refer to the information at the following link (the information applies to Sub-Instances as well, just be aware of the location of the sub-instance - SierraChartInstance_#): Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
