Date/Time: Wed, 27 Nov 2024 12:36:29 +0000
re Vertical Line
View Count: 274
[2023-08-07 13:50:36] |
User38606 - Posts: 106 |
Hi, I am looking to attach a value to the Vertical Line so that I can see the price level - how do I do that? Go to Tools > Vertical Line - when I place it on chart I cannot see the level it is placed at on my X axis. How do I make it visible / or appear on chart? |
[2023-08-07 15:10:15] |
John - SC Support - Posts: 36309 |
Do you want to see the Price or the Date-Time? You can not see a single price with a Vertical Line, as it is spanning multiple prices. In order to see the Date/Time associated with a Vertical Line, you will want to use the "Vertical Line" tool, and then there are options to display the "Date", "Time", or "Date and Time". Refer to the following: Chart Drawing Tools: Vertical Line Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-07 18:04:47] |
Oh apologies, i meant horizontal line, my bad. I want to see the corresponding price level when i place horizontal line. Thank u very much
[2023-08-07 18:27:54] |
JohnR - User831573 - Posts: 306 |
There is an option in the Horizontal line Properties pop up edit window. Just check the box "Price" on the 2nd tab of the edit window. Hope this helps, JohnR |
SC - HorzLinePrice--2023-08-07_14-20-33.jpg / V - Attached On 2023-08-07 18:27:44 UTC - Size: 75.39 KB - 71 views |
