Date/Time: Wed, 27 Nov 2024 12:25:39 +0000
Apex Tradovate
View Count: 735
[2023-08-07 11:28:28] |
Utilisateur188232 - Posts: 22 |
Bonjour, j'aimerais me lancer dans un compte financé chez Apex, ils utilisent le flux Tradovate, est ce que je peux connecter Tradovate sur sierra chart ? Si oui, comment ? Merci de votre réponsé. Mangione Lucas. |
[2023-08-07 14:58:41] |
John - SC Support - Posts: 36309 |
From Google Translate: Hello, I would like to start a funded account at Apex, they use Tradovate feed, can I connect Tradovate on sierra chart? If yes, how ?
APEX uses Rithmic for their data and order routing. So you would need to follow the instructions at the following link to connect your Sierra Chart to your APEX account: Rithmic Trading Platform Service We see that you are setup for the "CME E-Mini" professional exchange, so you will get the data for the symbols on that exchange from us and any other symbols would come from Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-07 15:58:44] |
Oui mais si je prend l’option avec rytmic je n’ai pas acces à l’Eurex, c’est pour ça que je voulais prendre l’option tradovate qui lui propose l’eurex en plus.
[2023-08-07 16:45:31] |
We do not know what it means to connect to APEX using Tradovate. We only support Rithmic, CQG, and our own Teton Order Routing service. You would have to ask APEX about this, as we simply do not know about this option or how it works. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
