Date/Time: Wed, 27 Nov 2024 12:22:38 +0000
Depth of market Data
View Count: 238
[2023-08-07 09:04:55]
nicktrader - Posts: 712
I would like the market depth to be saved in the "MarketDepthData" folder during "LIVE".
Had changed the settings for this and now can't find the corresponding "switch" anymore to save the data again.
Many thanks
[2023-08-07 14:32:23]
John - SC Support - Posts: 36309
On the Global Symbol Settings page, select the symbol for which you want to save the Market Depth data and change the setting for "Record Market Depth Data" to "Yes". Refer to the instructions at the following link:
Global Symbol Settings: Instructions
[2023-08-07 15:11:37]
Thank you John. As I read "Global Symbol Settings" it instantly came to my mind.
