Date/Time: Wed, 27 Nov 2024 12:33:45 +0000
About Interactive Brokers' live price data
View Count: 339
[2023-08-07 02:05:57] |
User513952 - Posts: 84 |
Hi: I am using Interactive Brokers (IB) as live data feeding source and order placement broker. Q1: From last Thursday, some stocks' live price data cound not be shown on SR platform until their symbols' name were changed to xxx-STK-SMART-USD (e.g. AMD, EWZ, GOOG, TSLA, NVDA, etc), please advise; Q2: ALso from last Thursday, once I connected SR, some stocks's live price could not show on IB's platform and resume visible once disconnected SR. BTW, I opened 40 lines on IB and 30 stocks on SR (total 70<100 symbols limit insturcted by IB). Please help to resolve it. Attached are the IB's API settings and IB's symbols' limit when SR is connected. Thanks Charlie |
tws1_API.JPG / V - Attached On 2023-08-07 02:03:25 UTC - Size: 132.16 KB - 75 views tws2_Diag.JPG / V - Attached On 2023-08-07 02:03:31 UTC - Size: 132.55 KB - 83 views |
[2023-08-07 14:11:42] |
John - SC Support - Posts: 36309 |
Q1. Refer to the following: https://www.sierrachart.com/SupportBoard.php?ThreadID=85624#P354709 Q2. There is nothing we can do to help with this as it is an Interactive Brokers issue. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-07 15:10:37] |
Q1: The thread was locked and failed to view
[2023-08-07 15:39:10] |
Sorry about that, we did not see that it was locked out. There was an issue with the Interactive Brokers symbols last week. This was resolved on Friday. You need to update your Symbol Settings by following these instructions: Global Symbol Settings: Update Symbol Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
