Date/Time: Wed, 27 Nov 2024 12:36:55 +0000
Number Bars Bold Highlight Last Trade Price Not Working?-
View Count: 306
[2023-08-05 21:03:47] |
user_xyz - Posts: 416 |
I can't get Last Trade Price to Bold or Highlight in my Number Bars / Footprint chart. Did something happen or is there another setting that prevents this? I tried setting Bid/Ask Bold = 0 that does NOT make a difference. Also did not see any dependencies here Numbers Bars: Bold/Highlight Last Trade Price Date Time Of Last Edit: 2023-08-05 21:04:18
[2023-08-07 13:51:20] |
John - SC Support - Posts: 36309 |
Is your Sierra Chart setup to use OpenGL for graphics? Refer to the following setting: Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other) If so, then what kind of Graphics Card are you using in your system? The reason for the above questions is that the issue you are seeing could be related to your graphics card. NVidia is the only vendor that has good support for OpenGL and if you are using an Intel or other graphics, then you may want to turn off the OpenGL and you should see the bolding after that. But, you should not be seeing an issue with the Highlighting, if you have turned that on. Check the colors you have set for the "Last Trae Bid[Ask] Highlight Color". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
