Date/Time: Wed, 27 Nov 2024 12:22:05 +0000
T&S alert sounds.
View Count: 247
[2023-08-05 19:10:48] |
User316362 - Posts: 210 |
Question, I notice my T&S sounds even when set to high number of trades before alerting, tend to get queued up according to the alert log. My question is there a setting that sets the length of time before another alert is heard? when I'm attempting to hear multiple sounds very quickly I do not. the speed seems limited. Also, perhaps the sound ".wav" files are too long for some of the sounds and cause the alert queue to build up. is there a way to get very short sound files that would help reduce/eliminate the queue (improving performance)? |
[2023-08-05 20:02:17] |
Sierra_Chart Engineering - Posts: 17191 |
No there is not: My question is there a setting that sets the length of time before another alert is heard?
Create your own: is there a way to get very short sound files that would help reduce/eliminate the queue (improving performance)?
