Date/Time: Wed, 27 Nov 2024 12:23:34 +0000
I need to convert my chartbook can sierra chart support help me plz
View Count: 311
[2023-08-05 16:51:59] |
Sivle - Posts: 53 |
my chartbook is not compatible can sierra chart support help me convert it. i have attached the chartbook file. |
G7FXPROFOOTPRINTCHARTBOOK-200409-002540.Cht - Attached On 2023-08-05 16:50:52 UTC - Size: 528.28 KB - 163 views Attachment Deleted. |
[2023-08-06 21:35:17] |
User303857 - Posts: 74 |
Try This: Edit > Translate Symbols to Current Service |
[2023-08-07 08:43:14] |
User907968 - Posts: 823 |
Did you try this - Chartbooks (Workspaces): Opening Older Chartbooks Does G7FX not provided up to date chartbooks? |
[2023-08-07 19:44:16] |
Sivle - Posts: 53 |
where can i finde older version of sierrachart so that i can convert it myself. So that i can open my converted chartbook in updated sierra chart.
[2023-08-08 08:57:04] |
Sierra_Chart Engineering - Posts: 17191 |
Here is a link to the version you need: https://www.sierrachart.com/downloads/ZipFiles/SierraChart2363.zip Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
