Date/Time: Mon, 21 Apr 2025 13:14:37 +0000
Lines connecting Parent/Child
View Count: 439
[2023-08-04 09:05:10] |
Thaddeus Fulmer - Posts: 71 |
Good morning, I attached a screenshot of a user that has lines connecting Parent/Child multiple limit orders. It makes it easier to see which OCO are connected. Also, Where do I find the documentation to show the ATR number only text on the screen. Please see screenshot. Thank you, Thaddeus |
[2023-08-04 13:17:57] |
John - SC Support - Posts: 39362 |
With regards to the connecting lines, refer to the following: Global Trade Settings Windows: Display Entry/Exit Connecting Lines (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) To display a value for a study on the screen like that, use the "Text Display for Study" study. Refer to the following: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-25 10:32:36] |
MTScalper - Posts: 19 |
It's impossible to remove parent child line after enable. I cant disable. I have disabled the display of child lines both globally and for the individual chart, but they are still visible on the chart. Sierra Chart version 2743. |
[2025-02-26 23:21:09] |
Sierra_Chart Engineering - Posts: 19285 |
The Trade order association lines are enabled and disabled with this setting: Global Trade Settings Windows: Order Association Lines (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
