Date/Time: Tue, 15 Sep 2026 22:46:44 +0000
Historical Data - Dividend Adjusted
View Count: 1923
| [2014-07-10 15:24:34] |
| NRGTrader - Posts: 351 |
I've noted that for some mutual funds, despite having "Global>DataSettings>HistoricalData>DownloadDividendAdjusted" checked, the historical data is not adjusted. Here is an example, PFSDX. Thanks in advance for checking
| [2014-07-10 19:49:22] |
In the next release, the Download Dividend Adjusted data option will definitely be followed. Whether it is now or not, is not entirely clear. After updating you will need to re-download the data in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
