Date/Time: Wed, 27 Nov 2024 12:25:46 +0000
[Programming Help] - alert formula
View Count: 573
[2023-08-02 19:37:28] |
User120564 - Posts: 11 |
Hello, For a LONG signal in automated trading I use: color bar based on alert condition. crossing of 2 moving averages, the fast crosses the slow one upwards. =CROSSFROMBELOW(ID1.SG1,ID2.SG1) the formula works perfectly. I would like to add the following additional condition: The difference between the FAST moving average and the slow one during the crossing must be => 3 ticks between the 2 moving averages for the LONG signal to be validated, if the difference between the 2 moving averages is < 3 ticks: NO SIGNAL , NO TRADE. THANK YOU for giving me the formula to automate this signal. Jean-Luc LEBLANC |
[2023-08-03 03:56:59] |
Sawtooth - Posts: 4120 |
How can there be a crossover if the MAs are separated Please explain further. |
[2023-08-03 12:11:18] |
once the crossover has been completed, the validation of the crossover as a signal is subordinate only if the fast moving average is equal to or greater than 3 ticks or more than the slow moving average = > 3 ticks. example: fast moving average: 15503 slow moving average: 15500 valid signal because the gap between the 2 moving averages IS HIGHER => 3 ticks. fast moving average: 15502 slow moving average: 15500 signal NOT valid because the difference between the 2 moving averages is LOWER < 3 ticks. THANK YOU for your help because I don't speak English. |
[2023-08-03 13:50:13] |
Try this: =AND(CROSSFROMBELOW(ID1.SG1,ID2.SG1),ID1.SG1-ID2.SG1>=TICKSIZE*3) |
[2023-08-03 15:01:59] |
it's not good, I have the message: alert formula error. Thank you for your help. |
[2023-08-03 18:15:04] |
That formula works for me in the Color Bar Based On Alert Condition study, without an error. where: ID1.SG1 is the fast MA ID2.SG1 is the slow MA |
[2023-08-04 16:00:09] |
OK formula it's good, thank you very much. Apparently the crossing is valid only during the T candle and if the gap is less than 3 ticks = no signal: normal, at the T1 candle after the crossing which is still valid with more than 3 gap ticks I have no signal and the same for T2... how can we do to have a signal during T1 when I did not have a signal at T because then I missed a trade. thank you for your help. |
[2023-08-04 16:43:10] |
What is a T candle? how can we do to have a signal during T1 when I did not have a signal at T because then I missed a trade.
Sorry, but I don't understand.
[2023-08-04 17:09:58] |
Tcandle is the candle where the moving averages cross precisely, T1 is the candle after the crossing at T.
[2023-08-04 17:47:15] |
The CROSSFROMBELOW function will only be TRUE at a single candle. Do you want a signal at all candles at and after the crossover, that also meet the 3 tick min separation? |
[2023-08-05 10:15:54] |
yes, that is exactly the signal i want. thank you very much.
[2023-08-05 13:23:47] |
Try this: =AND(ID1.SG1>ID2.SG1,ID1.SG1-ID2.SG1>=TICKSIZE*3) |
[2023-08-07 15:16:07] |
perfect Formula for LONG and SHORT. THANK YOU SO MUCH. Is it possible instead of COLOR BAR to replace with ARROW UP AND DOWN, I know it's not possible because I tried, maybe you know a way? if it is impossible how can I on the same graph to add the price candles below in order to see the real candles. Thank you for explaining to me the path to follow for that. |
[2023-08-07 15:48:39] |
You'd need two instances of the color bar study, one for each color/direction.And follow these instruction to use Arrows instead of color bars: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars |
[2023-08-07 17:00:13] |
THANK YOU that's OK, that's what I wanted. a different question: is it possible automatically from the opening time to the closing of the future u.s.a markets that a horizontal line tool of the lowest and one of the highest of each session move automatically with each new high or low of the day? instead of doing it manually. |
[2023-08-07 18:00:14] |
the lowest and .. the highest of each session move automatically with each new high or low of the day?
Use the High/Low For Time Period study, and set 'Display High Low Incrementally' to Yes.
[2023-08-08 14:56:00] |
Thank you, it works. Does putting this indicator on the automatic trading graph slow down the execution of trades or not? another question: when I open a position I have a sound, is it possible to choose a different sound for a gain output and another sound for a loss output? |
[2023-08-08 21:03:14] |
Imperceptibly.is it possible to choose a different sound for a gain output and another sound for a loss output?
Go to General Settings >> Notifications tab
