Date/Time: Wed, 27 Nov 2024 14:31:18 +0000
Sierra freezing when conncected to data feed
View Count: 297
[2023-08-02 18:20:41]
mrohacek - Posts: 3
Hi, I opened Sierra after like 7 days after moving into another appartment and suddenly Im having trouble when connected to data feed. WHOLE Sierra (not just data) freezes every 4 seconds for approximately 1 second. If I disconect it from data feed, it stops. I checked my computer and both CPU and memory are not overloaded (cpu running around 10-20% usage and memory around 40%) and I also never experienced this issue before. I tried to find the answer but with no succes, so I would like to kindly ask you for advice how to solve this problem.
Thank you very much.
Kind Regards.
[2023-08-02 18:31:42]
John - SC Support - Posts: 36312
It sounds like your Internet access is having an issue at the new apartment.
Get us your Message Log by following these instructions and we'll see if there is any particular information:
[2023-08-02 19:01:19]
mrohacek - Posts: 3
Internet is running fine, problem is that whole program is freezing, so every 4 seconds there is a freez for 1-2 seconds when I cant even click anything in menu or anywhere .. Whole Sierra just completely freezes during this time, then unfreez for these approximately 4 sedonds and then again freez for 1-2 secs. And it goes like this over and over again.
Message Log:
Reading Internal Order ID file. | 2023-08-02 14:51:34.231
Reading Trade Orders file. | 2023-08-02 14:51:34.287
Reading Trade Positions file. | 2023-08-02 14:51:34.287
Reading Trade Account Data files. | 2023-08-02 14:51:34.288
Software version: 2528 64-bit | 2023-08-02 14:51:34.288
Primary Thread ID: 15200 | 2023-08-02 14:51:34.288
Usage end date: 2023-08-11 | 2023-08-02 14:51:34.288
Enabled for: Advanced Features 2. | 2023-08-02 14:51:34.288
Enabled for: Sierra Chart Historical Data Service. | 2023-08-02 14:51:34.288
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-08-02 14:51:34.288
Enabled for: Delayed Denali Exchange Data Feed. | 2023-08-02 14:51:34.288
Enabled for exchange2: CME | 2023-08-02 14:51:34.288
Enabled for exchange2: fairx_exchange.data | 2023-08-02 14:51:34.288
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-08-02 14:51:34.288
Current selected Data/Trading service: Teton CME Order Routing | 2023-08-02 14:51:34.288
Custom symbol settings values: enabled | 2023-08-02 14:51:34.288
Chart Update Interval: 500 | 2023-08-02 14:51:34.288
Intraday Data Storage Time Unit: 0 | 2023-08-02 14:51:34.288
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-08-02 14:51:34.288
2023-08-02 18:51:34 Local computer time in UTC | 2023-08-02 14:51:34.288
2023-08-02 14:51:34 Local computer time in SC Time Zone | 2023-08-02 14:51:34.288
2023-08-02 18:51:33 Server time in UTC | 2023-08-02 14:51:34.288
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-08-02 14:51:34.288
Program path: C:\SierraChart\ | 2023-08-02 14:51:34.288
Data Files path: C:\SierraChart\Data\ | 2023-08-02 14:51:34.288
OS Version Number: 10.0 | 2023-08-02 14:51:34.288
Locale Setting: C | 2023-08-02 14:51:34.288
DLLs: UserContributedStudies_64.dll | 2023-08-02 14:51:34.289
Allowed protected custom studies: | 2023-08-02 14:51:34.289
Crash reporter started: true | 2023-08-02 14:51:34.289
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-08-02 14:51:34.299
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:34.324
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-08-02 14:51:34.365
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-08-02 14:51:34.365
Received 5 login tokens. | 2023-08-02 14:51:34.444
Symbol settings MD5 received. Request ID: 1. | 2023-08-02 14:51:35.581
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. | 2023-08-02 14:51:35.581
Requested user files to download. | 2023-08-02 14:51:36.788
Symbol settings received. Request ID: 2. | 2023-08-02 14:51:37.008
Teton CME Order Routing | Firm: IronBeam | 2023-08-02 14:51:38.786
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11085 | 2023-08-02 14:51:38.789
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-08-02 14:51:38.790
DTC Client socket (1) | New receive buffer size: 0 | 2023-08-02 14:51:38.790
DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-08-02 14:51:38.790
Teton CME Order Routing | Network connection to server complete. | 2023-08-02 14:51:38.909
Teton CME Order Routing | Starting socket receive thread. | 2023-08-02 14:51:38.909
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-08-02 14:51:38.909
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:39.271
Teton CME Order Routing | Sending logon request message. | 2023-08-02 14:51:39.271
Teton CME Order Routing | Received logon response. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Server Name: SC DTC Server. Build=46374. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-08-02 14:51:39.853
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Trading is supported. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Order cancel and replace is supported. | 2023-08-02 14:51:39.853
Teton CME Order Routing | OCO Orders supported. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Bracket Orders supported. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Connected to server complete. | 2023-08-02 14:51:39.853
Triggering next historical data download in queue. | 2023-08-02 14:51:39.853
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-08-02 14:51:39.856
No download requests in the queue to start downloads for. | 2023-08-02 14:51:39.856
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-06-15 14:01:26.435050 | 2023-08-02 14:51:39.859
Updated verified funded futures trading account ending date to: 2023-09-01 18:51:39 | 2023-08-02 14:51:39.974
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=32314019 | 2023-08-02 14:51:39.979
Files to Open on Startup | Opening file: ExampleChartbook.cht | 2023-08-02 14:51:42.006
XAUUSD 1 Min #1 | Reloading chart. | 2023-08-02 14:51:42.015
XAUUSD Daily #2 | Reloading chart. | 2023-08-02 14:51:42.031
US30 1 Min #3 | Reloading chart. | 2023-08-02 14:51:42.040
USOil 1 Min #4 | Reloading chart. | 2023-08-02 14:51:42.048
ESU23_FUT_CME 1 Min #5 | Reloading chart. | 2023-08-02 14:51:42.060
SPX500 Daily #6 | Reloading chart. | 2023-08-02 14:51:42.071
EURUSD Daily #7 | Reloading chart. | 2023-08-02 14:51:42.082
EURUSD 5 Min #8 | Reloading chart. | 2023-08-02 14:51:42.098
ESU23_FUT_CME #9 | Reloading chart. | 2023-08-02 14:51:42.110
ESU23_FUT_CME 1 Min #10 | Reloading chart. | 2023-08-02 14:51:42.282
AAPL-NQTV 5 Min #11 | Reloading chart. | 2023-08-02 14:51:42.322
Using Bid/Ask average for last trade price for XAUUSD | 2023-08-02 14:51:42.504
Using symbol data fast lookup vector | 2023-08-02 14:51:42.504
SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm | 2023-08-02 14:51:42.504
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-08-02 14:51:42.505
DTC Client socket (2) | Creating socket. | 2023-08-02 14:51:42.505
DTC Client socket (2) | New receive buffer size: 0 | 2023-08-02 14:51:42.505
DTC Client socket (2) | Connecting to IP: 142.215.18.101. | 2023-08-02 14:51:42.505
SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 1 | 2023-08-02 14:51:42.506
Starting DelayedDownloadMonitoringTimer | 2023-08-02 14:51:42.506
Starting HDTimeoutTimer | 2023-08-02 14:51:42.506
Added historical Intraday data request for XAUUSD to the queue. | 2023-08-02 14:51:42.507
Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2023-08-02 14:51:42.507
Triggering next historical data download in queue. | 2023-08-02 14:51:42.507
Delaying start of download for XAUUSD. | 2023-08-02 14:51:42.508
Added historical Daily data request for XAUUSD to the queue. | 2023-08-02 14:51:42.523
Triggering next historical data download in queue. | 2023-08-02 14:51:42.523
Using Bid/Ask average for last trade price for USOil | 2023-08-02 14:51:42.539
SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 2 Service code: fxcm | 2023-08-02 14:51:42.539
SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 2 | 2023-08-02 14:51:42.539
Added historical Intraday data request for USOil to the queue. | 2023-08-02 14:51:42.539
Intraday data recording state for symbol USOil is set to download 'Pending'. | 2023-08-02 14:51:42.539
Triggering next historical data download in queue. | 2023-08-02 14:51:42.539
Using Bid/Ask average for last trade price for US30 | 2023-08-02 14:51:42.541
SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 3 Service code: fxcm | 2023-08-02 14:51:42.541
SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 3 | 2023-08-02 14:51:42.541
Added historical Intraday data request for US30 to the queue. | 2023-08-02 14:51:42.541
Intraday data recording state for symbol US30 is set to download 'Pending'. | 2023-08-02 14:51:42.541
Triggering next historical data download in queue. | 2023-08-02 14:51:42.541
Mapping ESU23_FUT_CME to ESU23. Service code: cme | 2023-08-02 14:51:42.551
Denali Data Feed | Starting real-time market data updates for: ESU23_FUT_CME (ESU23). ID: 4 Service code: cme | 2023-08-02 14:51:42.551
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-08-02 14:51:42.552
DTC Client socket (3) | Creating socket. | 2023-08-02 14:51:42.552
DTC Client socket (3) | New receive buffer size: 0 | 2023-08-02 14:51:42.552
DTC Client socket (3) | Connecting to IP: 142.215.18.148. | 2023-08-02 14:51:42.552
Denali Data Feed | Requesting security definition data for: ESU23_FUT_CME (ESU23). ID: 4 | 2023-08-02 14:51:42.553
Added historical Intraday data request for ESU23_FUT_CME to the queue. | 2023-08-02 14:51:42.553
Intraday data recording state for symbol ESU23_FUT_CME is set to download 'Pending'. | 2023-08-02 14:51:42.553
Triggering next historical data download in queue. | 2023-08-02 14:51:42.553
Added historical Daily data request for SPX500 to the queue. | 2023-08-02 14:51:42.566
Triggering next historical data download in queue. | 2023-08-02 14:51:42.566
Using Bid/Ask average for last trade price for SPX500 | 2023-08-02 14:51:42.566
SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2023-08-02 14:51:42.566
SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 5 | 2023-08-02 14:51:42.566
Added historical Daily data request for EURUSD to the queue. | 2023-08-02 14:51:42.582
Triggering next historical data download in queue. | 2023-08-02 14:51:42.582
Using Bid/Ask average for last trade price for EURUSD | 2023-08-02 14:51:42.582
SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm | 2023-08-02 14:51:42.582
SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 6 | 2023-08-02 14:51:42.582
Added historical Intraday data request for EURUSD to the queue. | 2023-08-02 14:51:42.599
Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2023-08-02 14:51:42.599
Triggering next historical data download in queue. | 2023-08-02 14:51:42.599
SC DTC Data with Market Depth | Network connection to server complete. | 2023-08-02 14:51:42.635
SC DTC Data with Market Depth | Starting socket receive thread. | 2023-08-02 14:51:42.635
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-02 14:51:42.635
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESU23_FUT_CME | 2023-08-02 14:51:42.679
Teton CME Order Routing | Received security definition for symbol ESU23_FUT_CME | 2023-08-02 14:51:42.679
Denali Data Feed | Network connection to server complete. | 2023-08-02 14:51:42.682
Denali Data Feed | Starting socket receive thread. | 2023-08-02 14:51:42.682
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-02 14:51:42.682
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:42.783
SC DTC Data with Market Depth | Sending logon request message. | 2023-08-02 14:51:42.783
Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2023-08-02 14:51:42.817
SC DTC Delayed Exchange Data | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2023-08-02 14:51:42.817
SC DTC Delayed Exchange Data | Connecting to the server ds25.sierracharts.com. Port 10043 | 2023-08-02 14:51:42.818
DTC Client socket (4) | Creating socket. | 2023-08-02 14:51:42.819
DTC Client socket (4) | New receive buffer size: 0 | 2023-08-02 14:51:42.819
DTC Client socket (4) | Connecting to IP: 38.65.8.115. | 2023-08-02 14:51:42.819
SC DTC Delayed Exchange Data | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7 | 2023-08-02 14:51:42.820
Added historical Intraday data request for AAPL-NQTV to the queue. | 2023-08-02 14:51:42.820
Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2023-08-02 14:51:42.820
Triggering next historical data download in queue. | 2023-08-02 14:51:42.820
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:42.830
Denali Data Feed | Sending logon request message. | 2023-08-02 14:51:42.830
ESU23_FUT_CME[M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-08-02 14:51:42.880
SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-08-02 14:51:42.927
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-08-02 14:51:42.927
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-08-02 14:51:42.927
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:43.048
SC DTC Delayed Exchange Data | Sending logon request message. | 2023-08-02 14:51:43.048
SC DTC Data with Market Depth | Received logon response. | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Successfully connected. | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Trading is not supported. | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2023-08-02 14:51:43.535
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2023-08-02 14:51:43.535
SC DTC Delayed Exchange Data | Received logon response. | 2023-08-02 14:51:43.705
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-08-02 14:51:43.705
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-08-02 14:51:43.705
SC DTC Delayed Exchange Data | Successfully connected. | 2023-08-02 14:51:43.705
SC DTC Delayed Exchange Data | Trading is not supported. | 2023-08-02 14:51:43.705
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2023-08-02 14:51:43.705
Denali Data Feed | Received logon response. | 2023-08-02 14:51:43.705
Denali Data Feed | Server Name: SC Realtime Server. | 2023-08-02 14:51:43.705
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-08-02 14:51:43.705
Denali Data Feed | Successfully connected. | 2023-08-02 14:51:43.705
Denali Data Feed | Trading is not supported. | 2023-08-02 14:51:43.705
Denali Data Feed | Restarting real-time data updates for symbol: ESU23_FUT_CME -> ESU23 | 2023-08-02 14:51:43.705
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2023-08-02 14:51:43.753
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2023-08-02 14:51:43.753
SC DTC Data with Market Depth | Received security definition for symbol US30 | 2023-08-02 14:51:43.753
SC DTC Data with Market Depth | Received security definition for symbol USOil | 2023-08-02 14:51:43.753
SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2023-08-02 14:51:43.753
Denali Data Feed | Received security definition for symbol ESU23_FUT_CME | 2023-08-02 14:51:43.924
SC DTC Delayed Exchange Data | Received security definition for symbol AAPL-NQTV | 2023-08-02 14:51:43.924
ESU23_FUT_CME [CBV] #2 | Reloading chart. | 2023-08-02 14:51:44.940
ESU23_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol ESU23_FUT_CME starting at last date in file. | 2023-08-02 14:51:44.957
Starting DelayedDownloadMonitoringTimer | 2023-08-02 14:51:44.957
Starting HDTimeoutTimer | 2023-08-02 14:51:44.957
Added historical Daily data request for ESU23_FUT_CME to the queue. | 2023-08-02 14:51:44.957
Triggering next historical data download in queue. | 2023-08-02 14:51:44.957
ESU23_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 10, | 2023-08-02 14:51:44.994
ESU23_FUT_CME [CBV] 7500 Volume #4 | Reloading chart. | 2023-08-02 14:51:45.018
ESU23_FUT_CME [CBV] 7500 Volume #4 | Waiting for historical downloads to complete with the IDs: 10, | 2023-08-02 14:51:45.063
ESU23_FUT_CME #6 | Reloading chart. | 2023-08-02 14:51:45.090
ESU23_FUT_CME Renko 8t #7 | Reloading chart. | 2023-08-02 14:51:45.122
NQU23_FUT_CME [CBV] 2500 Volume #1 | Reloading chart. | 2023-08-02 14:51:45.151
NQU23_FUT_CME [CBV] 2500 Volume #1 | Performing continuous chart historical Daily data download for symbol NQU23_FUT_CME starting at last date in file. | 2023-08-02 14:51:45.157
Added historical Daily data request for NQU23_FUT_CME to the queue. | 2023-08-02 14:51:45.157
NQU23_FUT_CME [CBV] 2500 Volume #1 | Waiting for historical downloads to complete with the IDs: 11, | 2023-08-02 14:51:45.196
NQU23_FUT_CME [CBV] #5 | Reloading chart. | 2023-08-02 14:51:45.219
NQU23_FUT_CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 11, | 2023-08-02 14:51:45.264
Mapping ESZ23_FUT_CME to ESZ23. Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Starting real-time market data updates for: ESZ23_FUT_CME (ESZ23). ID: 8 Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Requesting security definition data for: ESZ23_FUT_CME (ESZ23). ID: 8 | 2023-08-02 14:51:45.278
Mapping ESH24_FUT_CME to ESH24. Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Starting real-time market data updates for: ESH24_FUT_CME (ESH24). ID: 9 Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Requesting security definition data for: ESH24_FUT_CME (ESH24). ID: 9 | 2023-08-02 14:51:45.278
Mapping ESM24_FUT_CME to ESM24. Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Starting real-time market data updates for: ESM24_FUT_CME (ESM24). ID: 10 Service code: cme | 2023-08-02 14:51:45.278
Denali Data Feed | Requesting security definition data for: ESM24_FUT_CME (ESM24). ID: 10 | 2023-08-02 14:51:45.278
Mapping 6BU23_FUT_CME to 6BU23. Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Starting real-time market data updates for: 6BU23_FUT_CME (6BU23). ID: 11 Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Requesting security definition data for: 6BU23_FUT_CME (6BU23). ID: 11 | 2023-08-02 14:51:45.279
Mapping 6BZ23_FUT_CME to 6BZ23. Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Starting real-time market data updates for: 6BZ23_FUT_CME (6BZ23). ID: 12 Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Requesting security definition data for: 6BZ23_FUT_CME (6BZ23). ID: 12 | 2023-08-02 14:51:45.279
Mapping 6BH24_FUT_CME to 6BH24. Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Starting real-time market data updates for: 6BH24_FUT_CME (6BH24). ID: 13 Service code: cme | 2023-08-02 14:51:45.279
Denali Data Feed | Requesting security definition data for: 6BH24_FUT_CME (6BH24). ID: 13 | 2023-08-02 14:51:45.279
HD Request # 1 | Downloading Historical Daily chart data for ESU23_FUT_CME. Starting date: 2023-07-28. Service: sc_futures_direct.dtc.trading | 2023-08-02 14:51:45.284
ESU23_FUT_CME[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-08-02 14:51:45.357
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ23_FUT_CME | 2023-08-02 14:51:45.399
Teton CME Order Routing | Received security definition for symbol ESZ23_FUT_CME | 2023-08-02 14:51:45.399
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH24_FUT_CME | 2023-08-02 14:51:45.400
Teton CME Order Routing | Received security definition for symbol ESH24_FUT_CME | 2023-08-02 14:51:45.400
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESM24_FUT_CME | 2023-08-02 14:51:45.400
Teton CME Order Routing | Received security definition for symbol ESM24_FUT_CME | 2023-08-02 14:51:45.400
Denali Data Feed | Received security definition for symbol ESZ23_FUT_CME | 2023-08-02 14:51:45.520
Denali Data Feed | Received security definition for symbol ESH24_FUT_CME | 2023-08-02 14:51:45.520
Denali Data Feed | Received security definition for symbol ESM24_FUT_CME | 2023-08-02 14:51:45.520
Denali Data Feed | Received security definition for symbol 6BU23_FUT_CME | 2023-08-02 14:51:45.520
Denali Data Feed | Received security definition for symbol 6BZ23_FUT_CME | 2023-08-02 14:51:45.520
Denali Data Feed | Received security definition for symbol 6BH24_FUT_CME | 2023-08-02 14:51:45.520
HD Request # 1 | Requesting historical Daily data for ESU23 starting at 2023-07-27. SC External HD service. | 2023-08-02 14:51:45.530
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BU23_FUT_CME | 2023-08-02 14:51:45.531
Teton CME Order Routing | Received security definition for symbol 6BU23_FUT_CME | 2023-08-02 14:51:45.531
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BZ23_FUT_CME | 2023-08-02 14:51:45.531
Teton CME Order Routing | Received security definition for symbol 6BZ23_FUT_CME | 2023-08-02 14:51:45.531
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH24_FUT_CME | 2023-08-02 14:51:45.531
Teton CME Order Routing | Received security definition for symbol 6BH24_FUT_CME | 2023-08-02 14:51:45.531
HD Request # 1 | Receiving historical Daily data for ESU23_FUT_CME starting at 2023-07-28. | 2023-08-02 14:51:45.877
HD Request # 1 | Writing historical Daily data to the file ESU23_FUT_CME.dly. | 2023-08-02 14:51:45.877
HD Request # 1 | Bytes received: 247 | 2023-08-02 14:51:45.879
HD Request # 1 | Received 4 Daily data records from 2023-07-28 00:00:00 to 2023-08-01 00:00:00 (5.0 days) and wrote 3 records for ESU23_FUT_CME | 2023-08-02 14:51:45.879
HD Request # 1 | Completion time: 0s. | 2023-08-02 14:51:45.879
HD Request # 1 | Daily data download complete for ESU23_FUT_CME. Unique request ID: 10 | 2023-08-02 14:51:45.879
Removing historical data download ID 10. | 2023-08-02 14:51:45.879
Triggering next historical data download in queue. | 2023-08-02 14:51:45.879
Mapping NQU23_FUT_CME to NQU23. Service code: cme | 2023-08-02 14:51:45.879
HD Request # 2 | Downloading Historical Daily chart data for NQU23_FUT_CME. Starting date: 2023-07-28. Service: sc_futures_direct.dtc.trading | 2023-08-02 14:51:45.880
ESU23_FUT_CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-08-02 14:51:45.929
ESU23_FUT_CME [CBV] #2 | Reloading chart. | 2023-08-02 14:51:45.930
ESU23_FUT_CME [CBV] 7500 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-08-02 14:51:46.004
ESU23_FUT_CME [CBV] 7500 Volume #4 | Reloading chart. | 2023-08-02 14:51:46.005
HD Request # 2 | Requesting historical Daily data for NQU23 starting at 2023-07-27. SC External HD service. | 2023-08-02 14:51:46.113
HD Request # 2 | Receiving historical Daily data for NQU23_FUT_CME starting at 2023-07-28. | 2023-08-02 14:51:46.288
HD Request # 2 | Writing historical Daily data to the file NQU23_FUT_CME.dly. | 2023-08-02 14:51:46.288
HD Request # 2 | Bytes received: 248 | 2023-08-02 14:51:46.290
HD Request # 2 | Received 4 Daily data records from 2023-07-28 00:00:00 to 2023-08-01 00:00:00 (5.0 days) and wrote 3 records for NQU23_FUT_CME | 2023-08-02 14:51:46.290
HD Request # 2 | Completion time: 1s. | 2023-08-02 14:51:46.290
HD Request # 2 | Daily data download complete for NQU23_FUT_CME. Unique request ID: 11 | 2023-08-02 14:51:46.290
Removing historical data download ID 11. | 2023-08-02 14:51:46.290
Triggering next historical data download in queue. | 2023-08-02 14:51:46.290
No download requests in the queue to start downloads for. | 2023-08-02 14:51:46.290
ESU23_FUT_CME [CBV] #2 | Reloading chart. | 2023-08-02 14:51:46.427
ESU23_FUT_CME [CBV] 7500 Volume #4 | Reloading chart. | 2023-08-02 14:51:46.602
NQU23_FUT_CME [CBV] 2500 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-08-02 14:51:46.692
NQU23_FUT_CME [CBV] 2500 Volume #1 | Reloading chart. | 2023-08-02 14:51:46.692
NQU23_FUT_CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-08-02 14:51:46.733
NQU23_FUT_CME [CBV] #5 | Reloading chart. | 2023-08-02 14:51:46.734
NQU23_FUT_CME [CBV] 2500 Volume #1 | Reloading chart. | 2023-08-02 14:51:47.192
NQU23_FUT_CME [CBV] #5 | Reloading chart. | 2023-08-02 14:51:47.277
Denali Data Feed | Starting real-time market data updates for: NQU23_FUT_CME (NQU23). ID: 14 Service code: cme | 2023-08-02 14:51:47.692
Denali Data Feed | Requesting security definition data for: NQU23_FUT_CME (NQU23). ID: 14 | 2023-08-02 14:51:47.692
Added historical Intraday data request for NQU23_FUT_CME to the queue. | 2023-08-02 14:51:47.692
Intraday data recording state for symbol NQU23_FUT_CME is set to download 'Pending'. | 2023-08-02 14:51:47.692
Triggering next historical data download in queue. | 2023-08-02 14:51:47.692
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQU23_FUT_CME | 2023-08-02 14:51:47.811
Teton CME Order Routing | Received security definition for symbol NQU23_FUT_CME | 2023-08-02 14:51:47.811
Denali Data Feed | Received security definition for symbol NQU23_FUT_CME | 2023-08-02 14:51:47.905
ESU23_FUT_CME[M] Renko 8t #7 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-08-02 14:51:47.937
HD Request # 3 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-08-02 14:51:48.506
HD Request # 3 | Download start date-time: 2023-08-02 14:50:21.000000. File last date-time: 2023-08-02 14:50:21.364000 | 2023-08-02 14:51:48.506
HD Request # 3 | Using server: ds12.sierracharts.com port 10149 | 2023-08-02 14:51:48.506
Socket (5) | Creating socket. | 2023-08-02 14:51:48.506
Socket (5) | New receive buffer size: 0 | 2023-08-02 14:51:48.506
Socket (5) | Connecting to IP: 142.215.18.101. | 2023-08-02 14:51:48.506
HD Request # 3 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:48.780
HD Request # 3 | Sending historical data logon request message. | 2023-08-02 14:51:48.780
HD Request # 3 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:21. Record interval: 0. Symbol: XAUUSD | 2023-08-02 14:51:49.426
HD Request # 3 | Decompressing data. | 2023-08-02 14:51:49.559
HD Request # 3 | Receiving Intraday data for XAUUSD starting at 2023-08-02 14:50:21.364000 | 2023-08-02 14:51:49.691
Socket (5) | CloseSocket call. | 2023-08-02 14:51:49.691
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:49.691
Historical data download thread signaled to stop. | 2023-08-02 14:51:49.691
HD Request # 3 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:22.648000. | 2023-08-02 14:51:49.691
HD Request # 3 | Received 160 Intraday data records from 2023-08-02 14:50:21.364000 to 2023-08-02 14:51:49.065000 (87.7 seconds. Delay: 0.6 seconds) and wrote 159 records for XAUUSD | 2023-08-02 14:51:49.691
HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:51:49.065000 | 2023-08-02 14:51:49.697
HD Request # 3 | Completion time: 1s. | 2023-08-02 14:51:49.698
HD Request # 3 | Intraday data download complete for XAUUSD. Unique request ID: 1 | 2023-08-02 14:51:49.698
Removing historical data download ID 1. | 2023-08-02 14:51:49.698
Real-time Intraday chart data file updates started for XAUUSD | 2023-08-02 14:51:49.698
Intraday chart data file opened for XAUUSD | 2023-08-02 14:51:49.698
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:51:49.698
Triggering next historical data download in queue. | 2023-08-02 14:51:49.698
HD Request # 4 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2023-07-31. Service: fxcm | 2023-08-02 14:51:49.699
HD Request # 4 | Using server: ds13-2.sierracharts.com port 10150 | 2023-08-02 14:51:49.699
Socket (6) | Creating socket. | 2023-08-02 14:51:49.700
Socket (6) | New receive buffer size: 0 | 2023-08-02 14:51:49.700
Socket (6) | Connecting to IP: 162.251.232.245. | 2023-08-02 14:51:49.700
Socket (5) | Socket gracefully closed by remote side. | 2023-08-02 14:51:49.823
Socket (5) | Closed. | 2023-08-02 14:51:49.823
Requesting market depth updates for: ESU23_FUT_CME if supported. NumLevels=100 | 2023-08-02 14:51:49.849
Denali Data Feed | Clearing market depth for ESU23_FUT_CME | 2023-08-02 14:51:49.993
HD Request # 4 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:50.000
HD Request # 4 | Sending historical data logon request message. | 2023-08-02 14:51:50.000
HD Request # 4 | Requesting historical Daily data starting at 2023-07-31. | 2023-08-02 14:51:50.758
HD Request # 4 | Decompressing data. | 2023-08-02 14:51:50.906
HD Request # 4 | Receiving historical Daily data for XAUUSD starting at 2023-07-31. | 2023-08-02 14:51:50.942
HD Request # 4 | Writing historical Daily data to the file XAUUSD.dly. | 2023-08-02 14:51:50.942
Socket (6) | CloseSocket call. | 2023-08-02 14:51:51.002
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:51.002
Historical data download thread signaled to stop. | 2023-08-02 14:51:51.003
HD Request # 4 | Received 3 Daily data records from 2023-07-31 00:00:00 to 2023-08-02 00:00:00 (3.0 days) and wrote 3 records for XAUUSD | 2023-08-02 14:51:51.003
HD Request # 4 | Completion time: 2s. | 2023-08-02 14:51:51.003
HD Request # 4 | Daily data download complete for XAUUSD. Unique request ID: 2 | 2023-08-02 14:51:51.003
Removing historical data download ID 2. | 2023-08-02 14:51:51.003
Triggering next historical data download in queue. | 2023-08-02 14:51:51.003
HD Request # 5 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2023-08-02 14:51:51.003
HD Request # 5 | Download start date-time: 2023-08-02 14:50:20.000000. File last date-time: 2023-08-02 14:50:20.815000 | 2023-08-02 14:51:51.003
HD Request # 5 | Using server: ds4.sierracharts.com port 10149 | 2023-08-02 14:51:51.003
Socket (5) | Creating socket. | 2023-08-02 14:51:51.006
Socket (5) | New receive buffer size: 0 | 2023-08-02 14:51:51.006
Socket (5) | Connecting to IP: 142.215.18.102. | 2023-08-02 14:51:51.006
XAUUSD[M] Daily #2 | Reloading chart. | 2023-08-02 14:51:51.024
Socket (6) | Socket gracefully closed by remote side. | 2023-08-02 14:51:51.150
Socket (6) | Closed. | 2023-08-02 14:51:51.150
HD Request # 5 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:51.272
HD Request # 5 | Sending historical data logon request message. | 2023-08-02 14:51:51.272
HD Request # 5 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:20. Record interval: 0. Symbol: USOil | 2023-08-02 14:51:51.916
HD Request # 5 | Decompressing data. | 2023-08-02 14:51:52.047
HD Request # 5 | Receiving Intraday data for USOil starting at 2023-08-02 14:50:20.467000 | 2023-08-02 14:51:52.178
Socket (5) | CloseSocket call. | 2023-08-02 14:51:52.179
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:52.179
Historical data download thread signaled to stop. | 2023-08-02 14:51:52.179
HD Request # 5 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:25.623000. | 2023-08-02 14:51:52.179
HD Request # 5 | Received 63 Intraday data records from 2023-08-02 14:50:20.467000 to 2023-08-02 14:51:40.740000 (80.3 seconds. Delay: 11.4 seconds) and wrote 59 records for USOil | 2023-08-02 14:51:52.179
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:51:40.740000 | 2023-08-02 14:51:52.186
HD Request # 5 | Completion time: 1s. | 2023-08-02 14:51:52.187
HD Request # 5 | Intraday data download complete for USOil. Unique request ID: 3 | 2023-08-02 14:51:52.187
Removing historical data download ID 3. | 2023-08-02 14:51:52.187
Real-time Intraday chart data file updates started for USOil | 2023-08-02 14:51:52.187
Intraday chart data file opened for USOil | 2023-08-02 14:51:52.187
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:51:52.187
Triggering next historical data download in queue. | 2023-08-02 14:51:52.187
HD Request # 6 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2023-08-02 14:51:52.187
HD Request # 6 | Download start date-time: 2023-08-02 14:50:21.000000. File last date-time: 2023-08-02 14:50:21.736000 | 2023-08-02 14:51:52.187
HD Request # 6 | Using server: ds12.sierracharts.com port 10150 | 2023-08-02 14:51:52.187
Socket (6) | Creating socket. | 2023-08-02 14:51:52.187
Socket (6) | New receive buffer size: 0 | 2023-08-02 14:51:52.187
Socket (6) | Connecting to IP: 142.215.18.101. | 2023-08-02 14:51:52.187
Socket (5) | Socket gracefully closed by remote side. | 2023-08-02 14:51:52.309
Socket (5) | Closed. | 2023-08-02 14:51:52.309
HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:52.463
HD Request # 6 | Sending historical data logon request message. | 2023-08-02 14:51:52.463
HD Request # 6 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:21. Record interval: 0. Symbol: US30 | 2023-08-02 14:51:53.109
HD Request # 6 | Decompressing data. | 2023-08-02 14:51:53.242
HD Request # 6 | Receiving Intraday data for US30 starting at 2023-08-02 14:50:21.019000 | 2023-08-02 14:51:53.374
Socket (6) | CloseSocket call. | 2023-08-02 14:51:53.375
Historical data download thread signaled to stop. | 2023-08-02 14:51:53.375
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:53.375
HD Request # 6 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:22.776000. | 2023-08-02 14:51:53.375
HD Request # 6 | Received 588 Intraday data records from 2023-08-02 14:50:21.019000 to 2023-08-02 14:51:52.883000 (91.9 seconds. Delay: 0.5 seconds) and wrote 583 records for US30 | 2023-08-02 14:51:53.375
HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:51:52.883000 | 2023-08-02 14:51:53.381
HD Request # 6 | Completion time: 1s. | 2023-08-02 14:51:53.381
HD Request # 6 | Intraday data download complete for US30. Unique request ID: 4 | 2023-08-02 14:51:53.381
Removing historical data download ID 4. | 2023-08-02 14:51:53.381
Real-time Intraday chart data file updates started for US30 | 2023-08-02 14:51:53.381
Intraday chart data file opened for US30 | 2023-08-02 14:51:53.381
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:51:53.381
Triggering next historical data download in queue. | 2023-08-02 14:51:53.382
HD Request # 7 | Downloading Intraday chart data for ESU23_FUT_CME to the file ESU23_FUT_CME.scid. Service: cme | 2023-08-02 14:51:53.383
HD Request # 7 | Download start date-time: 2023-08-02 14:50:21.000000. File last date-time: 2023-08-02 14:50:21.881000 | 2023-08-02 14:51:53.383
HD Request # 7 | Using server: ds26.sierracharts.com port 10149 | 2023-08-02 14:51:53.384
Socket (5) | Creating socket. | 2023-08-02 14:51:53.384
Socket (5) | New receive buffer size: 0 | 2023-08-02 14:51:53.384
Socket (5) | Connecting to IP: 142.215.17.188. | 2023-08-02 14:51:53.384
Socket (6) | Socket gracefully closed by remote side. | 2023-08-02 14:51:53.512
Socket (6) | Closed. | 2023-08-02 14:51:53.512
HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:53.651
HD Request # 7 | Sending historical data logon request message. | 2023-08-02 14:51:53.651
HD Request # 7 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:21. Record interval: 0. Symbol: ESU23 | 2023-08-02 14:51:54.333
Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 3380 | 2023-08-02 14:51:54.459
Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 3380 | 2023-08-02 14:51:54.460
Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 3380 | 2023-08-02 14:51:54.460
HD Request # 7 | Decompressing data. | 2023-08-02 14:51:54.467
HD Request # 7 | Receiving Intraday data for ESU23_FUT_CME starting at 2023-08-02 14:50:21.881000 | 2023-08-02 14:51:54.607
Socket (5) | CloseSocket call. | 2023-08-02 14:51:54.608
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:54.608
Historical data download thread signaled to stop. | 2023-08-02 14:51:54.608
HD Request # 7 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:22.352000. | 2023-08-02 14:51:54.608
HD Request # 7 | Received 2615 Intraday data records from 2023-08-02 14:50:21.881000 to 2023-08-02 14:51:53.305000 (91.4 seconds. Delay: 1.3 seconds) and wrote 2614 records for ESU23_FUT_CME | 2023-08-02 14:51:54.608
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:51:53.305000 | 2023-08-02 14:51:54.613
Added 25 Time and Sales records to Intraday data file for ESU23_FUT_CME after download. | 2023-08-02 14:51:54.614
HD Request # 7 | Completion time: 1s. | 2023-08-02 14:51:54.614
HD Request # 7 | Intraday data download complete for ESU23_FUT_CME. Unique request ID: 5 | 2023-08-02 14:51:54.614
Removing historical data download ID 5. | 2023-08-02 14:51:54.614
Real-time Intraday chart data file updates started for ESU23_FUT_CME | 2023-08-02 14:51:54.614
Intraday chart data file opened for ESU23_FUT_CME | 2023-08-02 14:51:54.614
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:51:54.614
Triggering next historical data download in queue. | 2023-08-02 14:51:54.614
HD Request # 8 | Downloading Historical Daily chart data for SPX500. Starting date: 2023-07-31. Service: fxcm | 2023-08-02 14:51:54.615
HD Request # 8 | Using server: ds13-2.sierracharts.com port 10150 | 2023-08-02 14:51:54.615
Socket (6) | Creating socket. | 2023-08-02 14:51:54.615
Socket (6) | New receive buffer size: 0 | 2023-08-02 14:51:54.615
Socket (6) | Connecting to IP: 162.251.232.245. | 2023-08-02 14:51:54.615
Socket (5) | Socket gracefully closed by remote side. | 2023-08-02 14:51:54.740
Socket (5) | Closed. | 2023-08-02 14:51:54.740
HD Request # 8 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:54.918
HD Request # 8 | Sending historical data logon request message. | 2023-08-02 14:51:54.918
HD Request # 8 | Requesting historical Daily data starting at 2023-07-31. | 2023-08-02 14:51:55.069
HD Request # 8 | Decompressing data. | 2023-08-02 14:51:55.218
HD Request # 8 | Receiving historical Daily data for SPX500 starting at 2023-07-31. | 2023-08-02 14:51:55.245
HD Request # 8 | Writing historical Daily data to the file SPX500.dly. | 2023-08-02 14:51:55.245
Socket (6) | CloseSocket call. | 2023-08-02 14:51:55.280
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:55.280
Historical data download thread signaled to stop. | 2023-08-02 14:51:55.280
HD Request # 8 | Received 3 Daily data records from 2023-07-31 00:00:00 to 2023-08-02 00:00:00 (3.0 days) and wrote 3 records for SPX500 | 2023-08-02 14:51:55.280
HD Request # 8 | Completion time: 1s. | 2023-08-02 14:51:55.280
HD Request # 8 | Daily data download complete for SPX500. Unique request ID: 6 | 2023-08-02 14:51:55.280
Removing historical data download ID 6. | 2023-08-02 14:51:55.280
Triggering next historical data download in queue. | 2023-08-02 14:51:55.280
HD Request # 9 | Downloading Historical Daily chart data for EURUSD. Starting date: 2023-07-31. Service: fxcm | 2023-08-02 14:51:55.281
HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2023-08-02 14:51:55.281
Socket (5) | Creating socket. | 2023-08-02 14:51:55.281
Socket (5) | New receive buffer size: 0 | 2023-08-02 14:51:55.281
Socket (5) | Connecting to IP: 142.215.18.102. | 2023-08-02 14:51:55.281
Socket (6) | Socket gracefully closed by remote side. | 2023-08-02 14:51:55.429
Socket (6) | Closed. | 2023-08-02 14:51:55.429
HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:55.545
HD Request # 9 | Sending historical data logon request message. | 2023-08-02 14:51:55.545
SPX500[M] Daily #6 | Reloading chart. | 2023-08-02 14:51:55.569
HD Request # 9 | Requesting historical Daily data starting at 2023-07-31. | 2023-08-02 14:51:55.677
HD Request # 9 | Decompressing data. | 2023-08-02 14:51:55.808
HD Request # 9 | Receiving historical Daily data for EURUSD starting at 2023-07-31. | 2023-08-02 14:51:55.819
HD Request # 9 | Writing historical Daily data to the file EURUSD.dly. | 2023-08-02 14:51:55.819
Socket (5) | CloseSocket call. | 2023-08-02 14:51:55.859
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:55.859
Historical data download thread signaled to stop. | 2023-08-02 14:51:55.859
HD Request # 9 | Received 3 Daily data records from 2023-07-31 00:00:00 to 2023-08-02 00:00:00 (3.0 days) and wrote 3 records for EURUSD | 2023-08-02 14:51:55.859
HD Request # 9 | Completion time: 0s. | 2023-08-02 14:51:55.859
HD Request # 9 | Daily data download complete for EURUSD. Unique request ID: 7 | 2023-08-02 14:51:55.859
Removing historical data download ID 7. | 2023-08-02 14:51:55.859
Triggering next historical data download in queue. | 2023-08-02 14:51:55.859
HD Request # 10 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2023-08-02 14:51:55.859
HD Request # 10 | Download start date-time: 2023-08-02 14:50:22.000000. File last date-time: 2023-08-02 14:50:22.176000 | 2023-08-02 14:51:55.859
HD Request # 10 | Using server: ds12.sierracharts.com port 10150 | 2023-08-02 14:51:55.859
Socket (6) | Creating socket. | 2023-08-02 14:51:55.859
Socket (6) | New receive buffer size: 0 | 2023-08-02 14:51:55.859
Socket (6) | Connecting to IP: 142.215.18.101. | 2023-08-02 14:51:55.859
Socket (5) | Socket gracefully closed by remote side. | 2023-08-02 14:51:55.988
Socket (5) | Closed. | 2023-08-02 14:51:55.988
EURUSD[M] Daily #7 | Reloading chart. | 2023-08-02 14:51:56.082
HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:56.135
HD Request # 10 | Sending historical data logon request message. | 2023-08-02 14:51:56.135
HD Request # 10 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:22. Record interval: 0. Symbol: EURUSD | 2023-08-02 14:51:56.265
HD Request # 10 | Decompressing data. | 2023-08-02 14:51:56.395
HD Request # 10 | Receiving Intraday data for EURUSD starting at 2023-08-02 14:50:22.176000 | 2023-08-02 14:51:56.526
Socket (6) | CloseSocket call. | 2023-08-02 14:51:56.526
Historical data download thread signaled to stop. | 2023-08-02 14:51:56.526
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:51:56.526
HD Request # 10 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:22.911000. | 2023-08-02 14:51:56.526
HD Request # 10 | Received 140 Intraday data records from 2023-08-02 14:50:22.176000 to 2023-08-02 14:51:48.209000 (86.0 seconds. Delay: 8.3 seconds) and wrote 139 records for EURUSD | 2023-08-02 14:51:56.527
Socket (6) | Socket gracefully closed by remote side. | 2023-08-02 14:51:56.659
Socket (6) | Closed. | 2023-08-02 14:51:56.659
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:51:48.209000 | 2023-08-02 14:51:59.648
Opened cached Intraday file: C:\SierraChart\Data\ESU23_FUT_CME.scid. Thread ID: 3380 | 2023-08-02 14:51:59.649
HD Request # 10 | Completion time: 4s. | 2023-08-02 14:51:59.651
HD Request # 10 | Intraday data download complete for EURUSD. Unique request ID: 8 | 2023-08-02 14:51:59.651
Removing historical data download ID 8. | 2023-08-02 14:51:59.651
Real-time Intraday chart data file updates started for EURUSD | 2023-08-02 14:51:59.651
Intraday chart data file opened for EURUSD | 2023-08-02 14:51:59.651
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:51:59.651
Triggering next historical data download in queue. | 2023-08-02 14:51:59.651
HD Request # 11 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2023-08-02 14:51:59.651
HD Request # 11 | Download start date-time: 2023-08-02 14:35:20.000000. File last date-time: 2023-08-02 14:35:20.917000 | 2023-08-02 14:51:59.652
HD Request # 11 | Using server: ds25.sierracharts.com port 10149 | 2023-08-02 14:51:59.652
Socket (5) | Creating socket. | 2023-08-02 14:51:59.652
Socket (5) | New receive buffer size: 0 | 2023-08-02 14:51:59.652
Socket (5) | Connecting to IP: 38.65.8.115. | 2023-08-02 14:51:59.652
HD Request # 11 | Setting DTC encoding to Binary VLS | 2023-08-02 14:51:59.873
HD Request # 11 | Sending historical data logon request message. | 2023-08-02 14:51:59.873
ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. | 2023-08-02 14:51:59.975
ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2023-09-01"}. Success=true | 2023-08-02 14:52:00.203
HD Request # 11 | Requesting Intraday data. Start date-time: 2023-08-02 14:35:20. Record interval: 0. Symbol: AAPL-NQTV | 2023-08-02 14:52:00.425
HD Request # 11 | Decompressing data. | 2023-08-02 14:52:00.533
HD Request # 11 | Receiving Intraday data for AAPL-NQTV starting at 2023-08-02 14:35:20.917000 | 2023-08-02 14:52:00.642
Socket (5) | CloseSocket call. | 2023-08-02 14:52:00.643
Socket (5) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:52:00.643
Historical data download thread signaled to stop. | 2023-08-02 14:52:00.643
HD Request # 11 | Timestamp of first Intraday data file record written: 2023-08-02 14:35:22.947000. | 2023-08-02 14:52:00.643
HD Request # 11 | Received 275 Intraday data records from 2023-08-02 14:35:20.917000 to 2023-08-02 14:36:57.980000 (97.1 seconds. Delay: 15.0 minutes) and wrote 274 records for AAPL-NQTV | 2023-08-02 14:52:00.643
HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:36:57.980000 | 2023-08-02 14:52:00.650
HD Request # 11 | Completion time: 1s. | 2023-08-02 14:52:00.650
HD Request # 11 | Intraday data download complete for AAPL-NQTV. Unique request ID: 9 | 2023-08-02 14:52:00.650
Removing historical data download ID 9. | 2023-08-02 14:52:00.650
Real-time Intraday chart data file updates started for AAPL-NQTV | 2023-08-02 14:52:00.650
Intraday chart data file opened for AAPL-NQTV | 2023-08-02 14:52:00.650
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:52:00.650
Triggering next historical data download in queue. | 2023-08-02 14:52:00.650
HD Request # 12 | Downloading Intraday chart data for NQU23_FUT_CME to the file NQU23_FUT_CME.scid. Service: cme | 2023-08-02 14:52:00.650
HD Request # 12 | Download start date-time: 2023-08-02 14:50:22.000000. File last date-time: 2023-08-02 14:50:22.171000 | 2023-08-02 14:52:00.650
HD Request # 12 | Using server: ds26.sierracharts.com port 10150 | 2023-08-02 14:52:00.650
Socket (6) | Creating socket. | 2023-08-02 14:52:00.650
Socket (6) | New receive buffer size: 0 | 2023-08-02 14:52:00.650
Socket (6) | Connecting to IP: 142.215.17.188. | 2023-08-02 14:52:00.650
Socket (5) | Socket gracefully closed by remote side. | 2023-08-02 14:52:00.751
Socket (5) | Closed. | 2023-08-02 14:52:00.751
HD Request # 12 | Setting DTC encoding to Binary VLS | 2023-08-02 14:52:00.919
HD Request # 12 | Sending historical data logon request message. | 2023-08-02 14:52:00.919
Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 17684 | 2023-08-02 14:52:01.113
HD Request # 12 | Requesting Intraday data. Start date-time: 2023-08-02 14:50:22. Record interval: 0. Symbol: NQU23 | 2023-08-02 14:52:01.564
HD Request # 12 | Decompressing data. | 2023-08-02 14:52:01.693
HD Request # 12 | Receiving Intraday data for NQU23_FUT_CME starting at 2023-08-02 14:50:22.171000 | 2023-08-02 14:52:01.826
Socket (6) | CloseSocket call. | 2023-08-02 14:52:01.827
Socket (6) | Shutdown started. Waiting for graceful close. | 2023-08-02 14:52:01.827
Historical data download thread signaled to stop. | 2023-08-02 14:52:01.827
HD Request # 12 | Timestamp of first Intraday data file record written: 2023-08-02 14:50:22.301000. | 2023-08-02 14:52:01.827
HD Request # 12 | Received 961 Intraday data records from 2023-08-02 14:50:22.171000 to 2023-08-02 14:52:02.082000 (99.9 seconds. Delay: -0.3 seconds) and wrote 960 records for NQU23_FUT_CME | 2023-08-02 14:52:01.827
HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2023-08-02 18:52:02.082000 | 2023-08-02 14:52:01.832
Added 4 Time and Sales records to Intraday data file for NQU23_FUT_CME after download. | 2023-08-02 14:52:01.833
HD Request # 12 | Completion time: 1s. | 2023-08-02 14:52:01.833
HD Request # 12 | Intraday data download complete for NQU23_FUT_CME. Unique request ID: 12 | 2023-08-02 14:52:01.833
Removing historical data download ID 12. | 2023-08-02 14:52:01.833
Real-time Intraday chart data file updates started for NQU23_FUT_CME | 2023-08-02 14:52:01.833
Intraday chart data file opened for NQU23_FUT_CME | 2023-08-02 14:52:01.833
HD Request # 12 | Enabling Intraday chart updating for symbol. | 2023-08-02 14:52:01.833
Triggering next historical data download in queue. | 2023-08-02 14:52:01.833
No download requests in the queue to start downloads for. | 2023-08-02 14:52:01.833
Socket (6) | Socket gracefully closed by remote side. | 2023-08-02 14:52:01.958
Socket (6) | Closed. | 2023-08-02 14:52:01.958
Opened cached Intraday file: C:\SierraChart\Data\NQU23_FUT_CME.scid. Thread ID: 3380 | 2023-08-02 14:52:04.684
Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 3380 | 2023-08-02 14:52:09.721
NQU23_FUT_CME [CBV][M] 2500 Volume #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-08-02 14:53:06.807
ESU23_FUT_CME [CBV][M] 7500 Volume #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2023-08-02 14:54:04.826
[2023-08-02 19:55:36]
There is nothing in your log that shows any issues.
Please go through the items at the following link, starting with #30.48 (as stated in the Introduction):
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
