Date/Time: Wed, 27 Nov 2024 14:21:03 +0000
Spread Matrix
View Count: 391
[2023-08-02 17:21:52] |
DayTraderEsad - Posts: 121 |
Do you have an option to open a spread matrix, for crude oil as an example? Or is this something that needs to be written in ASCIL to possible make my own version? |
[2023-08-02 18:19:10] |
John - SC Support - Posts: 36310 |
You can open the Exchange Traded Spreads by following these instructions: Denali Exchange Data Feed: Using Denali Futures Spread Data with Trading Service And you can create your own spread charts by using our "Custom Calculated Symbol" option. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-02 20:01:44] |
I know that, but what I am asking for is this. See attached picture. I am looking for a spread matric watchlist its basically a quote board for spreads |
spread matrix.PNG / V - Attached On 2023-08-02 20:01:05 UTC - Size: 16.68 KB - 127 views |
[2023-08-03 14:15:01] |
We do not have anything like that.
