Date/Time: Wed, 27 Nov 2024 14:39:24 +0000
Duplicate Chart (DOM) to another Chart (same chartbook)
View Count: 550
[2023-08-02 16:53:08]
User92573 - Posts: 530
Dear Support
I'd like to duplicate a configured DOM from the current chart to another so that all that requires changing is the link and Symbol.
I've tried
- Duplicate to Chart
- Duplicate to Chartbook
... as I would with a simple chart but this does not seem to work.
Any help appreciated.
Many thanks.
Date Time Of Last Edit: 2023-08-02 17:12:19
[2023-08-02 18:09:33]
John - SC Support - Posts: 36315
The options for "Duplicate Chart" and "Duplicate to Chartbook" should work fine. Just make sure you are actually selecting the option from the Trading DOM window itself and not from the main Sierra Chart window. Once you select "Chart >> Duplicate Chart" on the Trading DOM, it will open another Trading DOM window exactly like the previous one, but a different chart number.
It is also possible that when you do this the new Trading DOM is opening directly on top of the old one, so it appears that nothing has happened, but in fact you did create a new Trading DOM window - just select the Title Bar and move it a bit to see this.
As you noted, after you do the duplication, you will want to update the symbol and linking.
