Date/Time: Wed, 27 Nov 2024 13:06:47 +0000
[Programming Help] - Unmanaged Automated Trading not working
View Count: 414
[2023-08-02 12:58:53] |
User538264 - Posts: 26 |
Hi, I have been trying to use Unmanaged Automated Trading, but it seems that the restrictions are still in place for managing position. i.e., If I have an open long position with 2 lots and without any exit orders and then I try to place a limit sell order with 3 quantities to get net short 1 qty. But instead of doing this, it will first flatten the 2 long lots and then short 3 qty which will result in net 3 lots short. I am using sc.BuyOrder and sc.SellOrder for placing the orders and I have checked all the conditions of unmanaged trading but the issue still persists. Kindly help me with this. Thank You. |
[2023-08-08 00:16:55] |
ForgivingComputers.com - Posts: 960 |
Please post your unmanaged trading settings. Automated Trading Management: Unmanaged Automated Trading |
[2023-08-08 08:54:12] |
Sierra_Chart Engineering - Posts: 17191 |
But instead of doing this, it will first flatten the 2 long lots and then short 3 qty which will result in net 3 lots short. This does not make sense. You must actually be doing this in your automated trading system. Check the Trade Activity Log:Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-08 08:54:42
[2023-08-08 09:40:57] |
Here is a simple example code I am using to demonstrate this. It takes a long entry with 2 lots when there are two consecutive green bars printed on chart and places a limit sell order with 3 qty as soon as the entry is taken. I am also attaching a picture of the chart including the service log. You can see that as soon as I place the sell order, the position is flattened first and then the 3 lot sell order is placed. https://www.sierrachart.com/image.php?Image=1691487560369.png int32_t PlaceMarketEntry(SCStudyInterfaceRef sc, SCString longShort, int qty, SCString OrderTag) { s_SCNewOrder NewOrder; NewOrder.OrderQuantity = qty; NewOrder.OrderType = SCT_ORDERTYPE_MARKET; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; NewOrder.TextTag = OrderTag; if (longShort == "BUY") sc.BuyOrder(NewOrder); else sc.SellOrder(NewOrder); SCString msg; msg.Format("Market order with qty %d", qty); sc.AddMessageToLog(msg, 1); return NewOrder.InternalOrderID; } int32_t PlaceLimitEntry(SCStudyInterfaceRef sc, SCString longShort, int qty, double EntryPrice, SCString OrderTag) { s_SCNewOrder NewOrder; NewOrder.OrderQuantity = qty; NewOrder.OrderType = SCT_ORDERTYPE_LIMIT; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; NewOrder.TextTag = OrderTag; NewOrder.Price1 = EntryPrice; if (longShort == "BUY") sc.BuyOrder(NewOrder); else sc.SellOrder(NewOrder); SCString msg; msg.Format("Limit order - price %.02f with qty %d", EntryPrice, qty); sc.AddMessageToLog(msg, 1); return NewOrder.InternalOrderID; } SCSFExport scsf_aza_testBothSidePosition(SCStudyInterfaceRef sc) { SCString scriptName = "testBothSidePosition"; if (sc.SetDefaults) { sc.GraphName = scriptName; sc.GraphRegion = 0; //Main chart region sc.AutoLoop = 1; sc.MaximumPositionAllowed = 500; sc.AllowMultipleEntriesInSameDirection = true; sc.AllowOppositeEntryWithOpposingPositionOrOrders = true; sc.CancelAllOrdersOnEntriesAndReversals = false; sc.CancelAllWorkingOrdersOnExit = false; sc.AllowEntryWithWorkingOrders = true; sc.AllowOnlyOneTradePerBar = false; sc.SupportReversals = true; sc.MaintainTradeStatisticsAndTradesData = true; return; } if (sc.IsFullRecalculation && sc.Index == 0) sc.ClearAllPersistentData(); s_SCPositionData PositionData; sc.GetTradePosition(PositionData); if (sc.Close[sc.Index] > sc.Close[sc.Index - 1] && sc.Close[sc.Index - 1] > sc.Close[sc.Index - 2] && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED && !sc.IsFullRecalculation) PlaceMarketEntry(sc, "BUY", 2, scriptName); if (PositionData.PositionQuantity != 0 && !PositionData.WorkingOrdersExist) { PlaceLimitEntry(sc, "SELL", 3, sc.Close[sc.Index] + 10 * sc.TickSize, scriptName); } } Date Time Of Last Edit: 2023-08-08 09:44:33
[2023-08-08 14:41:01] |
Set : sc.SupportReversals= 0;
Refer to:Automated Trading Management: SupportReversals Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-08 15:14:33] |
Thanks a ton for this. Since there was nothing mentioned about sc.supportReversals on the documentation page of unmanaged autotrading, I missunderstood it. Also, I have tried it earlier too but it did not work apparently because I did not remove and reload the study at that time. It seems to be working now and I'll try this on my running studies. Thanks again, I appreciate the help. |
