Date/Time: Wed, 27 Nov 2024 14:30:19 +0000
Order modification failed with Teton CME Order Routing
View Count: 289
[2023-08-02 11:58:13]
User218244 - Posts: 21
Just received the following order modification failure at 07:42 (EST):
Order modification failed | Teton CME Order Routing (Order cancel/replace reject). Info: Order modification failed | Order Modification Reject. Text: Modification of orders from Iceberg to Non-iceberg & vice-versa is not allowed. Internal Order ID: 2033. Service Order ID: 189167. Symbol: MNQU23_FUT_CME. Account: [redacted] | 2023-08-02 07:42:12.174 *
The order was a limit order entered via DTC Server and there was no change in order type, and definitely not to an iceberg order.
[2023-08-02 13:43:31]
Sierra_Chart Engineering - Posts: 17194
Make sure you are not specifying a Display Quantity with the original order.
[2023-08-02 14:54:13]
Ok, I had it set to the full order quantity. Since the MaxShowQuantity field of SubmitNewOrderSingle is a non-optional double (according to the documentation), with Json encoding, should it be set to zero or actually set to null?
[2023-08-02 16:20:26]
Set it to 0.
