Date/Time: Wed, 27 Nov 2024 14:39:40 +0000
Fills don't appear in the trading activity log
View Count: 273
[2023-08-02 11:16:16] |
User266380 - Posts: 12 |
Hi I'm having an issue since yesterday where the fills don't appear in my trading activity log. They show up on the charts though. Could you please help me fix that?
Capture.PNG / V - Attached On 2023-08-02 11:15:59 UTC - Size: 75.99 KB - 76 views Attachment Deleted. |
[2023-08-02 11:52:39] |
Don't worry, i figured it out in the end, somehow it was disabled. I'm wondering if that happened as a result of the upgrade i did yesterday...
[2023-08-02 13:54:01] |
Sierra_Chart Engineering - Posts: 17194 |
The Trade Activity Log will be disabled on startup of Sierra Chart if you have the Use Risk Manager Mode enabled on the login window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-08-02 13:54:21
