Date/Time: Thu, 21 Nov 2024 13:05:01 +0000
Current price line
View Count: 717
[2023-08-02 09:26:12] |
Federico Roveda - Posts: 34 |
Hi, recently I cannot see the current price line study in my tpo chart and I do not know why. It's not hidden, by the way and the settings are the same as in other charts where it's visible. Any idea about how I can fix it? Thanks |
[2023-08-02 17:36:29] |
John - SC Support - Posts: 36174 |
In general, most studies do not work well with the TPO profile. Refer to the following: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart We tried the Current Price Line, and it does show up in the most recent TPO, so it should be there. But you might want to try using a different chart with the Current Price Line on it, and then use the Study/Price Overlay to put it on the TPO chart, just to make sure that something odd is not occurring with the TPO and the study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-04 07:45:23] |
I tried with the Study/Price Overlay study but did not work as well. It pretty weird because I used to have the Current Price Line study on this chart and was working. One day it started to not show up anymore for no reasons... On all other charts, the study is working.
[2023-08-04 13:15:40] |
Please get us that chartbook so we can take a look. Follow these instructions to attach a file (you can attach it privately if you like): https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-04 13:21:37] |
Chartbook definition in attachment. The chart I'm having issue with the Current Price Line study is #3 (Daily-MC-TPO). Thanks
[2023-08-04 15:25:05] |
We are not certain what is occurring, as we can see the line when we open your chartbook. But go to the Current Price Line study and on the Subgraphs tab make sure the Size/Width setting for the CPL subgraph is greater than 1. When it is set to 1 and dotted, this can cause the line to not be visible. Begin by making it at least 5 and make sure it shows, then you can reduce it to 2 and make sure it is still visible. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-14 15:59:40] |
jsandlan - Posts: 46 |
I ran into this issue as well on a TPO chart and the way I solved it was by going to Study Settings -> Current Price Line -> Settings and Inputs -> and then setting "Use Last Trade From Current Quote Data" to Yes
Date Time Of Last Edit: 2024-11-14 16:00:20
