Date/Time: Wed, 27 Nov 2024 14:30:19 +0000
The Chartbook file is not compatible.
View Count: 280
[2023-08-02 09:15:53]
BVdK - Posts: 2
I get this Message Log: The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\G7FXFOUNDATIONDOMCHARTBOOK.Cht | 2023-08-02 09:07:07.040 *
Could I get help with this please?
I attacked the file to this thread.
Looking forward hearing of you.
Thanks in advance.
Best regards, Bjorn.
Private File
[2023-08-02 16:52:13]
John - SC Support - Posts: 36312
You will need to update this chartbook by following these instructions:
Chartbooks (Workspaces): Opening Older Chartbooks
Or you will need to get an updated version from G7FX.
We keep getting postings from people regarding this chartbook. Where did you get it from?
[2023-08-02 18:05:34]
BVdK - Posts: 2
Great, thank you for your reply.
Got it from a friend. It is an older course so I got it.
[2023-08-02 18:27:59]
Thanks for the information.
