Date/Time: Wed, 27 Nov 2024 14:37:51 +0000
Currency value not updating
View Count: 247
[2023-08-02 07:23:23] |
arruga - Posts: 253 |
Why on this 5 min chart the currency value reported when I use the chart calculator tool does not update when I change the number of contracts on the trade window? On the 6o min chart for the same symbol, it updates just fine. Please advise Thanks https://www.sierrachart.com/image.php?Image=1690960774810.png |
[2023-08-02 16:47:38] |
John - SC Support - Posts: 36315 |
Refer to the information in the following section of the documentation for the "Currency Value": Chart Drawing Tools: Chart Calculator Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
