Date/Time: Wed, 27 Nov 2024 14:26:58 +0000
package recommendation
View Count: 235
[2023-08-02 07:03:56] |
User525733 - Posts: 126 |
which SC package is needed for the below scenarios: 1) ACSIL study development for FX trading ( using FXCM data) - no actual trading...just study development and back testing. 2) FX trading using IB as a broker + fxcm data are there any additional options to trade FX using SC besides IB? my understanding is that you guys are stopping LMAX soon. |
[2023-08-02 14:52:40] |
[2023-08-02 17:56:02] |
John - SC Support - Posts: 36311 |
1) Any package will work for study development. The real-time FXCM FOREX and CFD data is available with any Sierra Chart package. So you could use Package 3, our lowest cost package, if it has the features you need. Refer to the information here: Description of Service Packages and Pricing: Packages 2) In order to connect to an external trading service you would need to be on one of the "Integrated" packages. Refer to the information in the link given above for the Integrated packages. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
