Date/Time: Wed, 27 Nov 2024 14:41:53 +0000
Profiles on DOM move when scrolling vertically
View Count: 282
[2023-08-02 01:35:38] |
joshtrader - Posts: 488 |
I have two side-by-side profiles on the trade DOM, set to have 40% and 60% width, respectively. When I scroll so that the range contains fewer underlying bars, the profiles get very close together. When scrolling down so that more of the range is visible, the profiles are now at the desired 40%/60% of the width. Is there a way to prevent the profiles from moving, and just have them always stay in the position shown in the second picture? I could not find any information about this when searching or reading docs. Date Time Of Last Edit: 2023-08-02 01:36:10
[2023-08-02 16:08:50] |
John - SC Support - Posts: 36315 |
There is not a way to force the Volume by Price profiles to stay in a single position. The way these are drawn is dependent on the visible bars, so the profile to the left will move back and forth as the length of the visible volume bars from the profile on the right adjust.
[2023-08-02 16:25:49] |
User431178 - Posts: 544 |
This setting works for me Use Defined Width For Side By Side Profiles On Right, with width set at 50%, profiles are locked at 50% width regardless of vertical scroll position. Volume By Price Study: Use Defined Width for Side-By-Side Profiles on Right |
[2023-08-02 18:06:11] |
Thank you User431178 - we forgot about that option.
[2023-08-02 18:19:59] |
Thank you @User431178 ! Just what I needed. Seems that it would actually default to true, since most people would seem to want their user defined widths to be fixed.
[2023-08-02 18:34:17] |
Whenever a new option is added to a study we default the behavior to work as it did previously so as not to update existing users with changes to how something functions. This would be why that option is set to "No" by default. You can change the default settings for studies for your setup. Refer to the following: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
