Date/Time: Fri, 28 Feb 2025 01:48:20 +0000
Apex account Rithmic connection
View Count: 543
[2023-08-02 01:22:55]
JJTrade - Posts: 1
Hi I am trying to connect my apex account (through rithmic) to sierra charts. but i keep getting the error "Service Package does not support this function or account is expired. Select 'Help>>Account Control Panel' for account management."
I do not have a current service package for sierracharts
[2023-08-02 02:12:03]
Sierra_Chart Engineering - Posts: 18593
To be able to connect to an external service, which would include Rithmic, requires a paid Sierra Chart account.
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Account Control Panel" on the Sierra Chart software menu.
On the displayed webpage, click on "Activate Services".
Or you can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password if necessary.
2. Choose the particular Service Package and the number of Months that you want and press the "Update/Set" button. If you are on a Trial, you will first need to add sufficient credit to your account to pay for the chosen Service Package/Months. In this case, refer to the step below. Once that is done you can then choose the Service Package and number of Months.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
