Date/Time: Wed, 27 Nov 2024 14:19:30 +0000
On Screen indication Scale overidden? - or I have 'messed' with the chart scaling
View Count: 235
[2023-08-01 21:14:42] |
JohnR - User831573 - Posts: 306 |
Similar to the ability of the bottom right of the chart red / green "L" to let me know if I am at the end of the chart or not, I would like a way to know if I changed the scale -> I used Cntl - Left Mouse or left mouse to change visual how I see the price bars . After a while and multiple windows, I am not always sure the scaling state of each chart. Sooo -- Currently I need to move the mouse to the right scale area of each chart, then click to bring up the menu then click on Reset. Another platform will put a "F" in the top right of each subgraph section. I can then visually see what I need / want to return to the default scaling. If I just single click on the "F", that subgraph section of that chart returns to it defaults. Accomplishing in one click, what now takes many steps in SC. Hope this helps, JohnR |
[2023-08-02 15:55:50] |
John - SC Support - Posts: 36310 |
We do not have a way to denote that you changed the scale, but you do not need to right-click and then select Reset. A double-left click in the price ladder will reset the scale. Or you can create a keyboard shortcut or control bar option for this.
[2023-08-02 17:24:32] |
Excellent - thanks for the response. I'll use the double-left-click as suggested, as well as create an AHK macro that goes to each window price ladder and does it. As usual, It's in SC already. I do dig around - but did not find it when searched. Thanks for your time to reply. JohnR |
