Date/Time: Fri, 28 Feb 2025 01:39:23 +0000
AMP FUTURES BLOCKING
View Count: 375
[2023-08-01 19:54:33]
User410836 - Posts: 18
AMPFUTURES is blocking my access to sierra charts as my funds are on hold. is it possible to login the sierra charts to practice the charts till the funds clear as I am on Denali exchange DATA Feed...thanks
[2023-08-01 20:04:31]
John - SC Support - Posts: 38259
Within Sierra Chart, do the following:
- Select "Global Settings >> Data/Trade Service Settings".
- On the "Main Settings" page, set the option for "Current Selected Service" to "SC Data - All Services".
- Select OK twice (the first time will accept the entry you made, and show additional options for that service, then the second will actually close the window).
- When prompted to update your symbols select "Yes".
You will then be able to get your real-time data for the CME Group into your charts, but you will not be able to trade live.
Once your situation with AMP is worked out, then follow the instructions at the following link to connect to your CQG account:
CQG Trading Platform Service: Setup Instructions
And again, be sure to update your symbols. If you forget, or open a different chartbook, then select "Edit >> Translate Symbols to Current Service" to update the symbols for the currently selected service.
