Date/Time: Wed, 27 Nov 2024 14:26:41 +0000
Can't display my daily order fills
View Count: 391
[2023-08-01 18:40:59]
Dwaynzii - Posts: 11
Hi, I have an issue, order fills not display on my chart, I've check in my trade log history is good, I'm connected to the same data feed as I traded, same account, but on my chart (NQ) it's display DPL : 0 and on my trade window for this symbol it's DPL : 63, I don't know why the connection it's not established, thanks
[2023-08-01 18:59:18]
John - SC Support - Posts: 36311
Each Trade Window is associated with a specific chart. It sounds like the Trade Window you are viewing may not be for that specific chart. In addition, if the option for "Trade >> Only Orders From Chart" is selected, then you will only see the orders that are generated on that specific chart.
With regards to the Order Fills, refer to the following:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2023-08-01 19:02:14]
Ok, how can I retake the chart associated with my windows chart pls ?
[2023-08-01 19:05:47]
At the top of the Trading Window it gives the Chart # that it is associated with. You can use that to find the specific chart.
Another option would be to select "M >> Attach Trade Window to Chart Window" on the Trade Window and then find the chart that has the attached trade window.
[2023-08-01 19:09:22]
I only have the dom but no chart, how can I do ?
[2023-08-01 19:56:04]
Do you only have the 1 DOM in that Chartbook and no other charts?
[2023-08-01 19:58:21]
Yes my #6 NQ Windows trade only associated with my #6 NQ DOM, no chart
[2023-08-01 20:05:32]
And the DPL on these two windows are different?
Can you please get us a screenshot showing these two windows?
[2023-08-01 20:10:51]
File attached
Private File
[2023-08-02 15:48:29]
On the Chart that you have displayed that shows the DPL as 0.00, select "Trade >> Attach Trade Window to Chart". This will open and attach a Trade Window to that specific chart.
Then, on that attached trade window for that chart, check the Trade Account and make sure it is set the same as the Trade Window that is floating and associated with the Trading DOM that shows a DPL of 63.25. We see the Trade Account starts with "APEX-62591-22" We do not know if there is more. Refer to the following for how to set the Trade Account:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
Also, on that chart and on the Trading DOM, select the "Trade" menu at the top and make sure the option for "Only Orders from Chart" is not enabled (does not have a checkmark).
[2023-08-02 20:05:19]
Goat support, Thanks again
