Date/Time: Mon, 16 Sep 2024 19:10:07 +0000
FXCM DATA FEED
View Count: 939
[2014-07-09 19:58:07] |
User22153 - Posts: 46 |
Hello Support, I've purchased the US Equities from yourselves which is integrated into my Interactive brokers account. I was wondering if its possible to use the Sierra Charts FXCM data feed without using multiple installs. Is this possible? |
[2014-07-09 21:19:45] |
It is possible to use the FXCM data feed for historical data only when using Interactive Brokers. For this you just need to enable Global Settings >> Data/Trade Service Settings >> Support Alternate Forex Historical Data. For real-time data you will need to install a second copy of Sierra Chart on your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-09 21:23:18
