Date/Time: Wed, 27 Nov 2024 14:34:35 +0000
Data Question
View Count: 252
[2023-08-01 16:28:03]
Profit-Stalker - Posts: 8
We use AMP trading as our broker and have used Sierra Charts for years as our Chart Provider. We have a CQG for Order Routing ONLY username and password but was told to go to Teton. 1. Is this required or recommended? 2. Will I be able to trade other exchanges using Teton besides the CME. 3. We have purchased the Denali exchange, so how do we log onto the charts using the username and password given?
Thank you,
Profit-Stalker
[2023-08-01 17:47:37]
John - SC Support - Posts: 36314
1. Recommended.
2. No, the Teton Order Routing Service only works with the CME Group.
If you want, you can have one account setup to trade the CME Group using the Teton Order Routing Service and another account setup to trade a different exchange. With regards to Sierra Chart, you would need to have a second installation of Sierra Chart for the other exchange. There is no additional cost for Sierra Chart in this case, as long as both installations are on the same computer.
3. Using which Username and Password? If you are referring to CQG, then follow the instructions at the following link to setup your Sierra Chart to connect to CQG:
CQG Trading Platform Service: Setup Instructions
Also refer to the following regarding how our Denali Exchange Data Feed works with various services:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
