Date/Time: Wed, 27 Nov 2024 14:40:39 +0000
Trading dom en chartbook sames times
View Count: 236
[2023-08-01 16:21:45]
stephane1 - Posts: 111
Hi
I would like open Trading DOM and my chartbook at the same time when I selec symbol. is it possible ?
tku
[2023-08-01 17:30:26]
John - SC Support - Posts: 36315
If you are using the "Find Symbol" page, then you would select the button for "Open Intraday Chart" and then "Open Trading DOM". Refer to the following:
File Menu: Find Symbol (File)
Otherwise, you would want to have a Chartbook template setup that has a Chart and Trading DOM already setup in them, then you just have to change the symbols for each one. You can also use the linking option so you only have to change the symbol once and it will update to both.
Using Chart Templates
Chart Settings: Linking
