Date/Time: Wed, 27 Nov 2024 14:33:27 +0000
Problem with keyboard shortcut
View Count: 266
[2023-08-01 15:06:12]
Dorian - Posts: 57
I use the keyboard shortcut for Flat the position, and it works for position but not target. I would like it to also remove the target at the same time, like when I press the "Flatten" key on the "Trade Window For Chart" window.
I use the "Flatten Only" shortcut. The other shortcuts do not remove any position.
Thank you in advance for your answer.
[2023-08-01 15:12:47]
John - SC Support - Posts: 36313
You would need to use the "Flatten and Cancel" option.
The "Flatten" button on the Trade Window is really a "Flatten and Cancel".
Flatten, just removes the position and leaves the working orders. Flatten and Cancel removes the position and any working orders.
[2023-08-01 15:44:48]
Dorian - Posts: 57
Thank you.
