Date/Time: Wed, 27 Nov 2024 07:35:45 +0000
[User Discussion] - Dynamically display naked bar POC from numbers chart onto different chart in same chartboo
View Count: 460
[2023-08-01 10:59:40] |
User370813 - Posts: 4 |
I currently trade off 20k trade numbers chart/footprint chart in SC. I am looking to have those naked bar POCs on the numbers bars only display on a separate chart in the same chart book, and delete, add dynamically. I've tried study overlay without success. Is there another work around to have this functionality? |
[2023-08-01 11:11:40] |
User431178 - Posts: 543 |
Example of one possible solution attached.
ExtendAndCopyPOCExample.Cht - Attached On 2023-08-01 11:11:35 UTC - Size: 6.87 KB - 178 views |
[2023-09-08 01:15:24] |
I tried setting this up with the example you made but unfortunately doesn't seem to work with the numbers bars in the footprint chart I'm using. Any other possible solutions?
[2023-09-08 08:23:52] |
There is no reason for it not to work with number bars. Most likely you need to edit the alert formula in the color bar based on alert condition study to suit you chart. In the example it is =ID1.SG1<>0 If your volume point of control for bars study is not ID1, then it won't work. You need to make sure the correct ID number is used in the formula. |
