Date/Time: Wed, 27 Nov 2024 14:35:01 +0000
Alert on new Peak of Volume by Price?
View Count: 220
[2023-07-31 22:31:36] |
funbun - Posts: 90 |
I look for an alert each time there’s a new peak that´s formed on a given Volume by Price study. Is there any alert handle that can be used? |
[2023-08-01 13:34:47] |
John - SC Support - Posts: 36314 |
You can not create an alert for this directly on the Volume by Price. What you can do is use the "High/Low for Time Period" study and set it to the same time period as the Volume by Price study and also set the Input for "Display High Low Incrementally" to "Yes". Then the alert condition would be the following: =ID1.SG1 > ID1.SG1[-1] Where ID1 is the ID of the High/Low for Time Period and SG1 is the High Subgraph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
