Date/Time: Wed, 27 Nov 2024 14:26:39 +0000
Which Tool to use to check Price high and Price low of each bar?
View Count: 212
[2023-07-31 15:55:01] |
Sergio Anacleto - Posts: 9 |
Can you please advise what tool is available to check any price bar high and low ? Regards Sergio |
[2023-07-31 15:56:12] |
John - SC Support - Posts: 36311 |
You would use the Crosshairs with the "Tool Values Window". Refer to the following information: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
