Date/Time: Wed, 27 Nov 2024 14:38:44 +0000
Right click tools
View Count: 520
[2023-07-31 12:50:53]
Sylent - Posts: 6
When I right click on the chart is it possible to add the hand tool in the box?
[2023-07-31 13:04:23]
JohnR - User831573 - Posts: 306
This might be an area you could use.
Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu)
When right clicking on a chart with your pointing device, a menu will be displayed. This is called the Chart Shortcut Menu. This menu can contain whatever menu commands that you require.
Hope this helps,
JohnR
