Date/Time: Wed, 27 Nov 2024 14:35:01 +0000
Chart windows problem
View Count: 238
[2023-07-31 09:40:10] |
User825281 - Posts: 14 |
Hey, May I ask why the charts windows looks different? the ones with the VWAP cant be attached after I detach them, doesn't show the chart name etc, it's just giving me full screen with no "x" to close, option to minimize or the control bar to attach/take any other action. Would love to know how it can be fixed. thanks. |
צילום מסך 2023-07-31 123920.png / V - Attached On 2023-07-31 09:39:51 UTC - Size: 18.44 KB - 71 views צילום מסך 2023-07-31 123851.png / V - Attached On 2023-07-31 09:39:55 UTC - Size: 16.76 KB - 70 views |
[2023-07-31 10:51:28] |
Sierra_Chart Engineering - Posts: 17194 |
Enable the Title Bar and Menu on the detached chart: Chart Menu: Show Title Bar (Chart menu) Chart Menu: Show Menu (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-31 20:32:13] |
thanks!
